I got a case of the sag
Old Feb 7, 2011 | 10:46 AM
MadNismo's Avatar
MadNismo
Default I got a case of the sag
hey guys
i was at work today and noticed the gap between my left rear tire and wheel well was pretty close about an inch. i checked the other side and it was about 2inches. drove to a shop and the height was normal went home and now its an inch off again i installed tien s springs and tokico hp blues about 10 months ago and ive not had a problem with them. just wonder if its the spring or shock or something else? any info would be great
Old Feb 7, 2011 | 12:26 PM
arsey51's Avatar
arsey51
LOL - I had the same experience with my car. It depends on the surface your on - if the car is not on a level surface, there will be differences in wheel gap. You said you drove to a shop and it was level. Was this an auto shop? I took my car to my friend's shop whose floor is completely level, and the gap was equal on all four corners. he proved this to me by taking a 3 ft level and placing it on the floor in different locations and the level bubble was always in the middle. I tried this in my garage and noticed my floor droops to the left so my car always looks slightly higher on the right side than the left. So there's my two cents worth...........
Old Feb 7, 2011 | 01:20 PM
MadNismo's Avatar
MadNismo
I wish it was..id be so lucky. The parking lot in my apt complex is pretty level. Plus I just went to the shop and I noticed its still an inch different..but thank you.
Old Feb 7, 2011 | 01:22 PM
MadNismo's Avatar
MadNismo
Id like to add that the ride is normal. No knocks or clunks and feels smooth. Any info would be great thank you
Old Feb 7, 2011 | 02:40 PM
terrasmak's Avatar
How much gas, and always do suspension checks on a full tank. Our saddle tanks don't always sit level.
Old Feb 7, 2011 | 02:55 PM
MadNismo's Avatar
MadNismo
That's a good point but I've had this set up now for about 10 months and this would be the first time I've noticed this. Call me crazy but I do a walk around everyday 0_o
Old Feb 7, 2011 | 03:35 PM
MadNismo's Avatar
MadNismo
http://www.ehow.com/i/#article_4915686
Well that makes sense just sucks I don't want to buy 2 springs ill be stuck with one...anybody know where I can just get one spring?
Old Feb 7, 2011 | 08:40 PM
OkashiZ's Avatar
OkashiZ
There's grooves in the bottom "cup" and if the spring is not sitting in the groove correct, it may ride slightly higher. just check to see that the springs are sitting in the lower cup like thingy right.
Old Feb 8, 2011 | 12:25 PM
beezee's Avatar
beezee
1 inch difference seem significant. Since the rears are pretty easy, what I would do is take them out and redo the install. Maybe you would find something.
Old Feb 8, 2011 | 04:33 PM
MadNismo's Avatar
MadNismo
anybody have this setup? If so what is th gap between wheel well and tire. I always though it was odd that the height wasnt any different from stock. Maybe the
install wasn't done right and by some chance the one popped into place? 0_o
Old Feb 9, 2011 | 06:15 AM
MadNismo's Avatar
MadNismo
Just check the springs today everything seems to be in the right spot.
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
