BBK advice
Hey all, im looking at BBKs for my z.... I am short on funds and am thinking (for now) to go with a front BBK only until i can save up some money for the rear... ive heard of people doing this, but does anyone have anything to say against this?? Also how big of a difference am i looking at between a 4 piston and a 6 piston BBK? Im assuming the extra inch on the 14" rotors is a lot better then the 13" rotors... any advice is appreciated...
Front:
- 4-piston, 13" (330x28mm) 1-piece rotor
- 4-piston, 13" (330x28mm) 2-piece rotor
- 6-piston, 14.25" (362x32mm) 2-piece rotor
- Track kit: 6-piston, 14" (355x36mm) 2-piece full-floating rotor
- 4-piston, 13" (330x25.4mm) 2-piece rotor
- Track kit: 4-piston, 13" (330x25.4mm) 2-piece full-floating rotor
Chris
I have this setup and have had no problems. I've done 4 laps on the Nurburgring with the Z (6 total) and countless spirited driving on twisty, German country roads and haven't experienced any brake fade or premature wear on brake components whatsoever. Granted, you can only do one lap at the 'Ring at time, but that's one intense, 12.8 mile lap. I do have Stoptech rotors, HPS pads, and SS brake lines so I'm not too sure whether the basic setup will perform as well when pushed to the absolute limit. If I had the money, I would've went straight to the Brembo 6/4 caliper setup.
13" BBK allow you to run smaller (and somtimes lighter) 17" wheels.
you can also route brake ducting and hoses to help cool down 13" rotors... i suspect 90% of the people here will never overheat a 14" bbk on the track.... 13" kit is very sufficient for most needs.
looks.. well. that's a different story .. Rotor Envy and Piston Envy is ugly.
liqalu04
01-02-2022 12:58 PM
11-09-2020 10:27 AM
seagrasser
10-11-2015 03:27 PM
