how do you pull the rotor off?
Old Feb 23, 2011 | 09:00 AM
bjjbadboy's Avatar
bjjbadboy
Default how do you pull the rotor off?
Hey so Im getting ready for my new rotors to come and although have no problem taking every off in theory and through the diy etc not sure how to actually pull the rotor off? I am guess with a slap hammer, pull or something like that? Im sure I can google and search and have no prob doing so just fig if anyone wanted to chime in with some quick help would be cool. Not urgent still do not even have just courious thanks
Old Feb 23, 2011 | 09:02 AM
godzilla619's Avatar
godzilla619
unbolt your calipers and get them out of the way without putting too much strain on the brake lines. then pull or use a mallet to gently knock them loose to pull off.
Old Feb 23, 2011 | 09:23 AM
DavesZ#3's Avatar
DavesZ#3
PB Blaster or WD-40 around the junction of the rotor and hub will help loosen it.
Old Feb 23, 2011 | 09:50 AM
bjjbadboy's Avatar
bjjbadboy
Thanks guys.. yup I always zip tie the calipers to save the line when I play in there. Cant believe they come off that easy, are all cars like that?
Old Feb 23, 2011 | 09:56 AM
godzilla619
yep.
Old Feb 23, 2011 | 11:01 AM
R350Zz33's Avatar
R350Zz33
BFH
Old Feb 23, 2011 | 11:13 AM
scotts300's Avatar
scotts300
Just need to give the rotor a few wacks - I use a rubber mallet and tap around the circumference from the back side.
Old Mar 2, 2011 | 11:08 AM
Fixxxercask's Avatar
Fixxxercask
Don't forget to let your e-brake handle down. The rear rotors will not come off if the e-brake is engaged unless you have the BFH and superman swinging it. I have made this mistake before in the past and got super pissed and then I realized I left the e-brake on.
Old Mar 2, 2011 | 11:26 AM
r_seng's Avatar
r_seng
Rubber mallet.
Old Mar 2, 2011 | 12:01 PM
drivessidewayz's Avatar
drivessidewayz
Not all.
Old Mar 2, 2011 | 09:19 PM
tyau's Avatar
tyau
Use a rubber mallet!
You're not only going to hurt your back if you use a hammer, but you may also be driving on damaged rotor if you couldn't remove it. Spraying some PB Blaster or WD40 or liquid wrench into the crevice of the stud EASILY loosens it enough to be removed without a hammer!
Old Mar 2, 2011 | 10:46 PM
terrasmak's Avatar
I really liked using my 5 pound sledge , but have changed over to a 5 pound dead blow on them. Moral of the story, BFH of some kind.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
