Off with the old, ON with the BLUE...
Old Mar 18, 2011 | 07:01 AM
cubs4worldseris's Avatar
cubs4worldseris
Looking great man! Sent you a PM about your tokico blues fyii
Old Mar 18, 2011 | 09:29 AM
tally350z's Avatar
tally350z
All finished with the install. Now I am gonna take a break and then bleed the brake system..
Old Mar 18, 2011 | 11:06 AM
NoQuestionZ's Avatar
NoQuestionZ
I want white or blue brembos now mother EFFER!!!
This thread needs a NSFW label cuz my boss just walked over to look at what I was fapping to.........
Old Mar 18, 2011 | 11:12 AM
BornSlippyZ's Avatar
BornSlippyZ
The blue brembos look great op!
Old Mar 18, 2011 | 11:17 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
Originally Posted by tally350z
Got all the fronts off except for the bolt that holds the line onto the strut. Now I have tried to get it off for a few minutes now and the only thing that seems to happen is the flange bends.
Here is the picture of what I am talking about. If anyone has any tips or tricks to remove this without bending that piece.
I use this lil guy and long 12mm socket..comes out in seconds..
Old Mar 18, 2011 | 12:39 PM
VQ35deMax's Avatar
VQ35deMax
Mind if I ask how much powdercoating was and how are the seals now?
looks great btw
Old Mar 18, 2011 | 01:12 PM
tally350z's Avatar
tally350z
The powder coating was just under 200... Replaced all the seals and boots after I did the powder coating. The calipers were from an 04 G, and I just decided to replace them all..
Old Mar 19, 2011 | 04:56 AM
tally350z's Avatar
tally350z
Update:
So you know those details that you sometimes overlook because you are really excited about the product. Yea that happened to me. The guy I bought the calipers from said they were from an 04 G and it was the entire set.
After getting the rears installed with no issues, I started on the front. Got the front passenger side installed with no issues. When I went to go put the front driver side on I had to step back and think about this for on second.
The guy that sent me the calipers sent me two(2) front passenger calipers. The bleeder valves are on the bottom.. I have a couple of ideas on what could be done.
I can either:
1) Try to bleed that caliper as best I can by moving it so the bleeders are right side up.
2) Take it to a machine shop and see if they can drill out a hole where the bleeder valve is supposed to be. Might be an option only depends on how the caliper is built.
***Does anyone have a diagram of the caliper to see if the air channels inside run to this part so I can tell if this is even possible.
3) Go by a front driver side caliper and redo the whole process over by rebuilding and powder coating. Want to try to avoid this because it is expensive
**Unless someone on here is willing to trade a rebuilt Blue front passenger caliper for a driver side one...
Any other ideas will be much appreciated..
PS.. I feel like such an idiot for not realizing it earlier.
Old Mar 19, 2011 | 12:02 PM
Voboy's Avatar
Voboy
Update:
I can either:
Let's get the Z back on the road for now... option 1. It's not that bad... only two bolts for the caliper. Might be a pain to add that step for the future if you need to do flushes, but if you're not tracking you won't be flushing that often.... Sorry OP..
Seems like this guy is holding what you need, but charging an arm for it..
http://cgi.ebay.com/ebaymotors/Bremb...#ht_500wt_1182
Old Mar 19, 2011 | 04:05 PM
tally350z's Avatar
tally350z
Thanks,
I emailed the shop that I bought them from.
Apparently he had two sets of brembo's for sale and the guy who bought the other set was given two of the drivers side calipers. So the the shop is trying to get ahold of the guy to see if he can send him the caliper back, and then send to me.
If he doesn't then I will look at buying that one on ebay..
We did the flush again with the caliper right side up and it seemed alot better. I will do another one tomorrow on the whole car to see if it is better.
I will eventually be tracking so flushing the system will be happening pretty often.
Still does anyone have a diagram of the internals or know if the fluid channel runs to the other side of the back caliper??
Old Mar 19, 2011 | 04:17 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
are the pistons the same size? If not,then you will not want to use that passenger side caliper on the drivers side.
Old Mar 19, 2011 | 04:56 PM
rich2342's Avatar
rich2342
Thanks,
UNBELIEVABLE.... It's me. Mine just ****ing powdered and rebuilt. Only noticed after reading this thread and I got a V.M from vendor regarding a question they had.
Old Mar 19, 2011 | 06:43 PM
Voboy's Avatar
Voboy
Wow. Hopefully the shop will reimburse you for your troubles :| . Good luck guys.
Old Mar 19, 2011 | 08:52 PM
ImWeeZzel's Avatar
ImWeeZzel
glad to see you guys found each other!
Old Mar 19, 2011 | 09:18 PM
lgear080's Avatar
lgear080
CLAASSSSSSIC sorry guys
Old Mar 20, 2011 | 03:47 AM
Kuhan's Avatar
Kuhan
It's a small world!
Good luck to both of you.
Old Mar 20, 2011 | 05:39 AM
rich2342's Avatar
rich2342
Going to have a nice conference call with Good ole Al....
Old Mar 20, 2011 | 08:07 AM
  #38
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Default Wow
Wow... too bad you didn't powdercoat them the same color so that you could just cross-ship and be done.
Old Mar 26, 2011 | 06:00 AM
  #39
rich2342's Avatar
rich2342
Got the caliper.. Thanks. Blue is a really sick color really nice.
silents1ick
South East Marketplace
Nov 26, 2014 06:07 PM
brownie
Wheels Tires
Aug 1, 2013 09:57 AM
silents1ick
Jun 6, 2012 05:51 PM
jeedup35
Mid-Atlantic Marketplace
16
Oct 12, 2011 08:40 AM
trebien
Jan 10, 2009 11:23 AM
