brake light keeps coming on
Old Mar 17, 2011 | 03:30 PM
350Shadow's Avatar
350Shadow
Default brake light keeps coming on
so i recently installed my stoptech st 40 fronts and everything seemed to be fine. but about a week later my brake light would come on everytime id brake hard and go away once i let off and its still doing this.. any ideas as to what would be causing this?? thanks guys
Old Mar 17, 2011 | 03:40 PM
DavesZ#3's Avatar
DavesZ#3
Low Brake fluid. Read your owners manual, it tells you what those annoying warning lights mean.
Old Mar 17, 2011 | 05:58 PM
350Shadow's Avatar
350Shadow
it cant be low brake fluid though ive checked it a few times and its still at max....idk ill see whats up in the manual again though thank you
Old Mar 18, 2011 | 03:15 AM
DavesZ#3's Avatar
DavesZ#3
When you brake hard, the fluid sloshes to the front of the reservior causing a drop in the level causing the float to drop and trigger a low fluid warning. At least that's what's happens in 99% of these cases. If your fluid is above the half-way mark, then you might have some other problem.
Old Mar 18, 2011 | 08:50 PM
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
Could it be air in the system? Maybe when you get on the brakes you force the fluids through the lines and your reservoir gets low. Then when you get off the brakes the air forces the fluid back into the reservoir.
Old Mar 19, 2011 | 07:03 AM
DavesZ#3's Avatar
DavesZ#3
Air would mean he'd have soft squishy brakes, almost to the point of not being able to stop. With a new setup, surely he'd be concerned if that was the case.
OP when you replaced the brakes, did you allow all the fluid to drain out of the system? How did you bleed after re-filling? Any chance the ABS pump ran dry?
It would still seem like you'd have little or no brakes if there was a problem with the ABS pump or if it wasn't bled properly.
Obadabot
Jun 18, 2023 11:31 PM
loudtoyz
Apr 6, 2023 04:52 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
