Eibach sportlines?
Old Aug 12, 2011 | 09:08 AM
03_db350z's Avatar
03_db350z
Default Eibach sportlines?
I was looking into getting some lowering springs for the Z and not sure what to go with i have 19/10.5 +12 offset rears and 19/9.5 +12 offset fronts i have already rolled the fenders just dont know if the sportlines will be too low, where i live isnt exactly forgiving to lowered cars but i want something to look and feel a difference and sit flush with the wheels plus the car has 75,000 miles on it and still on stock struts as well so will prolly be upgrading them very shortly as well and with new struts will it raise the car up seeing how the oem ones are worn down?
Old Aug 12, 2011 | 09:14 AM
TheFarmer's Avatar
TheFarmer
No to everything you asked
What size tires are you running?
Old Aug 12, 2011 | 09:20 AM
03_db350z's Avatar
03_db350z
Im running 275/35 rear and 245/35 front so your saying dont go with the eibachs or there not too low
Old Aug 12, 2011 | 09:23 AM
TheFarmer's Avatar
TheFarmer
They're not too low. You should be fine with those tire sizes since you already have your fenders rolled.
Old Aug 12, 2011 | 09:29 AM
03_db350z's Avatar
03_db350z
ok awesome thanks for the help!
Old Aug 12, 2011 | 01:03 PM
03_db350z's Avatar
03_db350z
oh and one more thing, a rear camber kit would prolly be good to get as well right? i heard if it lowers the car over 1.5 inches itll throw the camber out of factory specs just dont want to be eating the tires up
Old Aug 12, 2011 | 04:20 PM
Bmurray350z's Avatar
Bmurray350z
Sportlines aren't low at all. Should be perfect if you want that "low but not too low" look.
Old Aug 12, 2011 | 07:58 PM
kelsey_kaye's Avatar
kelsey_kaye
a camber kit is usually recommended. some have said they didn't need one, but most say to get a camber kit.
Old Aug 13, 2011 | 04:55 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Sportlines will require a rear camber/toe kit - Eibach also make sa very nice kit for this purpose, that works well and is affordable. A front kit isn't mandatory at this point with what you're trying to achieve
Some of the aftermarket struts are a bit shorter vs stock - Sportlines are not a spring you want to run on stock shocks with 75k miles.
Old Aug 15, 2011 | 09:03 AM
03_db350z's Avatar
03_db350z
ok awesome ill look into getting a camber/toe kit as well thanks for all the help!
Bodyboarder81
Nov 2, 2015 12:17 AM
seagrasser
Oct 11, 2015 03:27 PM
