Caliper Bracket Bolts
Old Sep 1, 2011 | 07:28 PM
ReUhssurance's Avatar
ReUhssurance
Default Caliper Bracket Bolts
Hey guys, I'm trying to replace my brake pads and rotors currently and have run into an issue. I'm doing the front right side right now, I have the pads out and now I have to remove the 22m bolts. I've Wd-40'd the hell out of them and have been banging the hell out of the socket wrench with both a metal and a rubber mallet and it hasn't seemed to budge. Anyone have any pointers for this? I'm hitting it down and to the right (clockwise) as I face into the wheel well obviously and don't believe these are reverse threaded.. Anyways everywhere I looked simply said that they were a ***** to get off and be careful but no real methods that helped. Anyone have any ideas? Help would be appreciated!
Old Sep 1, 2011 | 08:11 PM
onthe3rdday's Avatar
onthe3rdday
Penetrant oil overnight. Banging wont do it, but a medium pipe over the rachet or 1/2 flex handle will do it.
Old Sep 1, 2011 | 11:16 PM
winchman's Avatar
winchman
The service manual says to use a power tool. I assume they mean an impact wrench.
Old Sep 2, 2011 | 07:47 AM
ReUhssurance
Definitely do have an impact gun :/ and have never heard of penetrant oil. Will check it out though, I've had the bolts marinating in wd40 so hopefully that might alleviate the problem so I don't have to take any other measures. Thanks for the replies though!
Old Sep 2, 2011 | 09:05 AM
terrasmak's Avatar
22mm wrench , use the box end side and bang it with a 5 pound sledge.
Old Sep 3, 2011 | 02:48 PM
ian99rt's Avatar
ian99rt
Wd-40 is not a very good penetrating oil. PB-blaster is the best there is, is say 30 mins soak will do it.
1/2" breaker bar with a pipe for more leverage will do it.
Old Sep 3, 2011 | 03:48 PM
ReUhssurance
Exactly what we did. It worked but was the most difficult I've seen (I'm a noob mechanic clearly). I broke a pvc pipe (whatever the black one is it wasn't white) so we had to go out and bought a metal one and that did the trick with me kicking my weight into it.
Old Sep 3, 2011 | 04:32 PM
ian99rt's Avatar
ian99rt
Did WD-40 loosen it up or you ended up with PB Blaster?
Always a good idea to have a good 3' metal pipe for leverage, as well as a 3' 2X4.
Old Sep 3, 2011 | 05:38 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Be sure to use a 6point socket when you plan to use a mallet.
Old Sep 12, 2011 | 05:53 PM
ReUhssurance
Sorry for the late replies. I did have a 6 point socket on with the mallet as that felt the most stable to me. Also we sprayed the crap out of the bolts with both WD40 and PB Blaster. I don't feel like either loosened it or help much to be honest. With the bolts on the right I had the pipe kind of under the front bumper and I just about kicked my entire weight onto the pipe. The left side it was under the bumper again but I was able to get my left hand on the ground and rip up with my right hand. Crap was a pain but good experience for me nonetheless!
Old Sep 25, 2011 | 10:16 AM
defcon83's Avatar
defcon83
I know i might be too late, but I had a similar problem with my s2000 when I had it. And I tried everything you can imagine, I ended up using a large monkey wrench on the bucket and a steel bar for leverage and it finally came loose.
Old Oct 26, 2011 | 09:50 PM
thespottedcow's Avatar
thespottedcow
I found it helped if i turned the wheel towards the outside, so you could get easier access to the bolt, and even with a 1/2" drive breaker bar it was a *****. Torque spec is 130-140 lb pounds fyi o.o
AbrasiveRaysive
Sep 20, 2021 02:29 PM
