1 bolt away from a freshly dropped z :(
Old Sep 18, 2011 | 09:31 PM
aasorah's Avatar
aasorah
Default 1 bolt away from a freshly dropped z :(
I have given up for the night with just 1 bolt to go before I put the wheel back on and head to the allignment shop. The swaybar endlink bolt will just spin. Am i missing something. The left front just unscrewed and screwed back on.. Idk if I have messed something up or if there is a nut i have missed. Can someone help me out here.
It is the middle bolt.
Attached Thumbnails 1 bolt away from a freshly dropped z :(-img00046-20110919-0112.jpg
Old Sep 18, 2011 | 09:36 PM
Rocknthehawk's Avatar
Rocknthehawk
probably busted it inside on the other end. Fortunately, a new one is like $9. When I dropped mine, I got frustrated and used a hammer to get it out...killing the threads. it won't kill you to drive it for now, just don't drive super aggresive.
Old Sep 18, 2011 | 09:49 PM
winchman's Avatar
winchman
Go to http://www.courtesyparts.com/54618-a...4_715_800_802& to see enlarged picture.
If you look closely at the enlarged picture you'll see one end has an internal recess for an Allen-head wrench, and the other end has a piece to keep the bolt from rotating. Can't tell from the picture which end goes up/down, though.
My guess is the recess is filled with dirt.
Old Sep 18, 2011 | 10:08 PM
terrasmak's Avatar
I could swear there is a spot on the backside to put a wrench on.
Old Sep 18, 2011 | 11:10 PM
Stock2Autocrozz's Avatar
Stock2Autocrozz
^lol, terra...always there wit da funny stuff.....
Op, is this your first drop? Whats your chosen setup?...etc....
Old Sep 18, 2011 | 11:15 PM
Duckeee's Avatar
Duckeee
also need a hex key to keep it from spinning
Old Sep 18, 2011 | 11:35 PM
SuperBlack350z's Avatar
SuperBlack350z
are both front wheels off the ground?
Old Sep 19, 2011 | 02:20 AM
winchman's Avatar
winchman
Two other possibilities:
The splines that hold the clip from turning may have sheared, and it doesn't hold.
The bolt may be pushed through the hole too far, and the clip isn't touching the arm.
Old Sep 19, 2011 | 04:08 AM
JasonZ-YA's Avatar
JasonZ-YA
ya, ummm Terra is right........
OP if this is your problem now, R U SURE you did your install right?
and yes, there is an allen key hole at end of stud as well..
-J
Attached Thumbnails 1 bolt away from a freshly dropped z :(-endlink-wrench-spot.jpg   1 bolt away from a freshly dropped z :(-img00046-20110919-0112.jpg
Old Sep 19, 2011 | 04:20 AM
Russ@Z1's Avatar
Russ@Z1
+1 on the post by Jason.
That's how it/they should be installed.
Old Sep 19, 2011 | 07:34 AM
aasorah's Avatar
aasorah
Jasonz-ya Thanks a ton. Makes sense now that I see that piece separate. This is my first install and I'm running the gf210's. The other side didn't break free so it puzzled me when this side did. It was late last night and the fatigue was getting to me. Thanks a ton for the replies!
Old Sep 19, 2011 | 11:22 AM
terrasmak's Avatar
Wasn't trying to be funny
Old Sep 19, 2011 | 07:26 PM
BrandonHeat's Avatar
BrandonHeat
Terra is correct. You have to double wrench or use the allen setup. It's a 13/16" wrench at least that's what I use. I have coilovers and mess with the front all suspension all the time.
Old Sep 20, 2011 | 08:49 AM
aasorah's Avatar
aasorah
Thanks, Ya i used the allen wrench and got it all tightened back up. Everything is on now and I'm waiting on my alignment appointment come thursday.
Old Sep 20, 2011 | 12:37 PM
Stock2Autocrozz
I found it funny whether you were trying or not. never debated whether you were correct or not, I knew you were
Old Sep 20, 2011 | 05:21 PM
BrandonHeat
I didn't proofread at all apparently lol
