kw variant 2 + spl mid-link=?
Old Sep 20, 2011 | 10:10 AM
GuardDrgn86's Avatar
GuardDrgn86
Default kw variant 2 + spl mid-link=?
anyone know if the rear spring for the variant 2 setup will fit in the spl mid-link spring seat? I have a set of swifts springs right now but changing my setup and just checking my spring options besides swift. don't want to have to get new springs if the variant ones will work.
Old Sep 21, 2011 | 10:03 AM
GuardDrgn86
guess I should mention that I'm looking into buying the KW2 and do not own them yet (I do already have the spl mid-links on the car) therefore I cannot test this theory. anyone have the ability to test?
Old Sep 21, 2011 | 10:18 AM
suprasam's Avatar
suprasam
Your springs need to be taperer/flat at least on the bottom to sit properly in the mid-links
Old Sep 21, 2011 | 11:24 AM
GuardDrgn86
I thought as much. It seems from photos of the KW2's that the base of the rear springs appear to be flat. That and the inner diameter of the spring is all I need to know to test it myself but it would be nice if someone has the ability to do it first hand and not by measurements.
Old Jan 20, 2012 | 11:29 AM
TrueBlueZ's Avatar
TrueBlueZ
Bump.........I'm looking in to the same thing, OP did you ever figure this out?
Old Jan 20, 2012 | 09:52 PM
SoCal07HR's Avatar
SoCal07HR
I thought the KW v2 came with a progressive rear that is much larger at the bottom. I don't know for sure though.
I am also running the SPL midlink setup with a swift spring. The drawback to using them with the v2's is the damper is not adjustable for length so you won't be able to adjust your droop like is covered in the instructions for the midlinks. I guess you could adjust droop at the midlink but it will be a guessing game a who knows what your ride height will end up like.
Old Jan 21, 2012 | 07:02 AM
TrueBlueZ's Avatar
TrueBlueZ
So what combo are you using with your swift springs then? i really want to get rid of the factory ecentric bolts but would like to stay with an oem type suspension. I dd my z sometimes, but mostly hit the backroad curves and will be doing track time so something in the kw v2 or v3 range is my goal.
Old Jan 21, 2012 | 07:12 AM
SoCal07HR's Avatar
SoCal07HR
I'm running custom valved JIC Magic monotubes with Swift springs all around. 10kg/mm front, 8kg/mm rear.
Old Jan 21, 2012 | 07:13 AM
SoCal07HR's Avatar
SoCal07HR
Do you own the KW's or midlinks yet?
Old Jan 21, 2012 | 08:44 AM
TrueBlueZ's Avatar
TrueBlueZ
No, only had the Z for 6 months now. Saving up and doing my research so I'm ready when the bank account is. Getting ready do do urethane bushing upgrades/replacements and don't want to replace the factory mid link bushings if I'm going to replace the whole link.
Old Jan 21, 2012 | 10:42 AM
SoCal07HR's Avatar
SoCal07HR
Here's a pic I found in one of the stickies at the top.
It's easy to see the V2 spring won't work with the midlinks.
Old Jan 22, 2012 | 07:41 PM
Gsedan35's Avatar
Gsedan35
Backroads V2 is fine
Track, the V3 will likely be a better choice.
But either setup uses a progressive rear spring with a wide rate spread.
EDIT: You cannot use the KW rear spring because the part of their spring that is 65mm ID just like the spl lower seat pan, is actually the top of the KW rear spring. And you can't just flip their spring, part that is ment to sit in the lower control arm wouldn't be flat and not the correct outside diameter.
KW coilovers Variant's 1,2&3
twintube construction,
V1=non adjustable dampning,
V2=adjustable rebound damping,
V3=separate adjustability for compression damping AND rebound damping .
Spring rates Front 485lbs to 525Lbs Rear: 240Lbs to 548Lbs (progressive springs)
Min and Max ride height Front: -.8”/-1.5” Rear: -.8”/-1.5”
Old Jan 22, 2012 | 07:47 PM
Gsedan35's Avatar
Gsedan35
see revised post above
Old Jan 23, 2012 | 06:40 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you also have to take into consideration the height of the spring
the SPL midlinks are designed to take a very standard sized, universal spring with 63.5mm ID. You don't need to use Swift - tons of companies make them - Tein, H&R, Eibach, etc etc etc
Old Jan 23, 2012 | 10:34 AM
suprasam's Avatar
suprasam
http://www.splparts.com/tech.html
The midlinks use a 2.5 ID spring so you would have to measure your KWs. Above is a link to the SPL site. Go to the 350z section and look for the spring calculator. That will help determine the length base on spring rate and desired ride height.
Old Jan 24, 2012 | 06:51 PM
Gsedan35's Avatar
Gsedan35
SoCal07's post number 11 is totally correct. Edited my post.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
