autopower roll bar question
hey i just bought a autopower 4 point race roll bar from a local guy its brand new but it didnt come with any instructions you can weld it or bolt it to the chassis dose any one know what kind of bolts are strong enough to use to mount the roll bar
u need grade 8 fasteners, thats bolts and nuts!!, the bolts will have 5 dashes on the head, and the nuts will have dots. A local nut and bolt place it best, stay away from large chain stores, bolts may not actually be full grade just knock off's. a local place where i am, is called Bolts Plus, someone there will be able to help u... if ure not sure,, dont do it!! there are paid professionals, that do it for a reason!! good luck
weld in can be removed but costly, bolt in is fine if its occasionally tracked, always check with local track rules and race regulations, if its street only, sure bolt in is fine,
and if the shop has installed roll bars before they will know what bolts u need, once someone sees what they need to do. and determine what size bolts will be used. the bolts will need to be a certain length, and thickness etc...
if you're welding it/modifying it.. make sure that main hoop gets as high to the ceiling as possible..
i never liked how the off-the-shelf autopower bars had the main hoop so low... what good is a roll bar if it allows the roof to cave in 6 inches before it does anything?
