Installing New Coilovers
Old Oct 20, 2011 | 06:59 PM
Juni0r's Avatar
Juni0r
Default Installing New Coilovers
Well guys, Im going to be installing Stance GrPlus true coilovers and in need of some advice. Ive seen some DIY but nothing on the true coilover DIY. Shouldn't be to tough. I have the coilovers and the rear toe rodsto eliminate the spring bucket. Do I need a spring compression kit to remove the rear springs?
If you guys know of any true coilover DIY I would appreciate it, Thx.
Old Oct 20, 2011 | 07:07 PM
guitman32's Avatar
guitman32
No rear compression kit needed.
Old Oct 20, 2011 | 07:11 PM
jduet's Avatar
jduet
It's the same exact process as an OEM style coilover minus placing a new spring in the bucket
Old Oct 21, 2011 | 08:21 PM
Juni0r's Avatar
Juni0r
Oh ok, well Where can i get the torque specs?
Old Oct 21, 2011 | 08:25 PM
guitman32's Avatar
guitman32
Factory service manual, brah
Old Oct 22, 2011 | 06:10 AM
sportbiketed's Avatar
sportbiketed
^this
Old Oct 22, 2011 | 10:42 AM
Juni0r's Avatar
Juni0r
Well I got the back coilovers and toe rod installed, didnt get camber kits, but looks like Im going to need them. Ill post some pics in a bit. What i did notice is that the toe rods made the back rotors slant somewhat both vertical and horizontal.
Old Oct 22, 2011 | 11:14 AM
Juni0r's Avatar
Juni0r
Well this is the result of the Stance at 3/4 of the lowest setting.
I still need to tighten the toe rods, but dont believe it will fix the slant much.
Old Oct 22, 2011 | 12:38 PM
guitman32's Avatar
guitman32
Nice job.
Youre gonna need some camber arms in order to fix the rear camber.
Old Oct 22, 2011 | 01:10 PM
r_seng's Avatar
r_seng
Good, now bring it back up so your Z doesn't like that.
Old Oct 22, 2011 | 01:38 PM
Juni0r's Avatar
Juni0r
yea i will def adjust it, Now Im having trouble with the front part. Ill update in a bit
Old Oct 22, 2011 | 05:06 PM
JDMStanced's Avatar
JDMStanced
nice man
Old Oct 22, 2011 | 05:57 PM
Juni0r's Avatar
Juni0r
thx, well apparently i stripped out a bolt and need to get replaced.
Old Oct 23, 2011 | 04:03 PM
Juni0r's Avatar
Juni0r
Well this was the end result, still need the camber kits to get ordered. And I obviously still need to adjust the height on the rear.
Need to fix this ****. >
stock height:
Old Oct 23, 2011 | 04:05 PM
Juni0r's Avatar
Juni0r
Any recommendations on Camber kits?
Old Oct 23, 2011 | 05:09 PM
Bmurray350z's Avatar
Bmurray350z
Looks good. Look at the eibach camber kits. I think they go for like ~$750
Old Oct 27, 2011 | 09:27 AM
mvp2765's Avatar
mvp2765
spc rear camber arms & front a-arms together are around $525 new
Old Oct 27, 2011 | 09:32 AM
Kirbaaybaayy's Avatar
Kirbaaybaayy
+1 but the rears are way cheaper and an easy install but the fronts wear out a lot faster than the backs keep that inmind
