this might help. I've been checking myself. I'm about to pull the trigger on the KW v2s. From a month or so of research it seems that they may go as low as 2-3" but 1.5 is recommended for best performance. Don't quote me cause I'm not done researching. Also try search in different ways to find good threads about KW. Such as KW, KW v1, KW variant, KW coilovers... There's lots out there. Some titles have nothing to do with KW but people talk about them in the thread.
You CANNOT adjust a setup without full height adjustablity that much. We're talking about a setup that adjusts height via spring preload.
Kw recommends a drop range of .8" to 1.5". As you drop closer to the max range your willingly giving up bump travel. Go past their max drop specs and your making the bump stops a bigger and bigger player. NOT a good idea
Kept within their recommended drop range, it's a great product.
