I absolutely cannot decide what coilover or spring/shock combo to get?...
Old Feb 21, 2012 | 05:35 PM
braydo25's Avatar
braydo25
Default I absolutely cannot decide what coilover or spring/shock combo to get?...
Hey guys, so I'm somewhat new to the forum. I got my 350z back in September and haven't really modded it yet aside from a small front lip.
So, I'd like to not spend more than $1,500 between coilovers or spring/shock combo and the other necessary things I'll need to get my alignment back within spec.
I'm looking to have a little of everything - although for only $1,500 I'm sure I'll have to sacrifice some aspects of ride quality? I'd like to get about a 1.5" - 2" drop, I'm not looking to absolutely slam the car, just close those fender gaps.
I'd like to improve handling - I'm not going to be tracking it every single day, but every few months they do have auto-x events at the local track and I do enjoy participating in them, so something that can still be somewhat comfortably driven daily.
All suggestions are appreciated!
Thanks!
Old Feb 21, 2012 | 05:41 PM
Are we certain that lowering the car improves handling or is that a truism?
Old Feb 21, 2012 | 06:12 PM
SirSpeedyZ's Avatar
SirSpeedyZ
If I had that budget for a coilover I would have bought the used KW2 kit that was for sale here. I'd rather buy used german quality than cheap crap.
Go to the coilover thread and start making a list of the kits in your price range and go from there.
Old Feb 21, 2012 | 06:52 PM
hugo350z's Avatar
hugo350z
from my experiences, the z handles best from stock height up to one inch lower. 2 inches might handle worse, it did in my case. I bought used JIC ftl ar2's and could be happier. For performance, I would recommend buying higher end used coilovers with your budget. But, save more and you can get better/new coilovers.
Old Feb 21, 2012 | 06:56 PM
terrasmak's Avatar
On a car that sits 3.8 inches off the ground at its lowest point. Dropping 1 inch is pretty much slamming the car. Wheel gap is needed norma, you need suspension travel for proper handling.
Old Feb 21, 2012 | 07:09 PM
albinobob's Avatar
albinobob
Lowered (lower center of gravity) + Coilovers (reducing body roll) = yes (in ideal conditions )
You can go with your cheaper brand coilovers I.E. BC, D2, Ksport,
I got my Ksports over a year ago and have beat the hell out of them with no problems which isn't bad for $750
Godspeed rear camber arms again I've put these to the test with no complaints and they go for $70 on ebay
Stance rear tow arms (bucket deletes) about $250 last I checked
+$100 alignment
And you're looking at a grand total of about 1300-1400 when all is said and done.
FYI I'm rocking about 2 degrees of camber in the front with stock A-arms
Old Feb 21, 2012 | 07:18 PM
terrasmak's Avatar
Originally Posted by albinobob
Lowered (lower center of gravity) + properly selected spring rates (reducing body roll)+ proper dampening (Ksport, BC, Megan and Stance do not provide) + proper suspension geometry (not much room to lower a Z before it gets fcuked) = yes (in ideal conditions )
Fixed for you
Old Feb 21, 2012 | 07:22 PM
hugo350z's Avatar
hugo350z
Old Feb 21, 2012 | 07:48 PM
hndumafia's Avatar
hndumafia
look into a true choice stage 2 (or do they call it phase 2?) setup. if i recall correctly, this should be koni yellows shocks that are revalved + sleeve over kit, and custom springs.
I don't know exact pricing bc I never spoke with True choice, and trying to find info on this setup was like looking for a unicorn when I was shopping. And I ended up finding another very gently used kit at a price I couldn't refuse. That said, I believe pricing should be close to the $1,500 mark, and the True Choice setups have great reviews.
Old Feb 21, 2012 | 07:54 PM
lgear080's Avatar
lgear080
aragosta, zeal, kw
Old Feb 21, 2012 | 08:48 PM
+$100 alignment
Thanks but I am asking braydo25.
Old Feb 21, 2012 | 10:19 PM
cnz's Avatar
cnz
I just bought some Gr+ true style recently and so far they are very nice. I don't track my car or anything but on normal roads they ride great, I've got them paired up with ichiba camber arms and custom toe arms made by a member on here. They go pretty low as well. I got the coilovers with helper springs shipped to my front door for 1299$.
Old Feb 22, 2012 | 05:52 AM
SE5spd's Avatar
SE5spd
This was a reccondation from 03threefiftyz
-Buy KONI yellows
After that:
Front sleeves (truechoice)
-Rear spring perches
-Springs from summit (Eibach)
-Front upper strut mounts ~$100
I think KONI phase II are around your price range too.
Old Feb 22, 2012 | 06:16 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
These posts come up every couple days, and you end up with the same replies, often by the same people, sometimes by different people.
Spend your time researching, read the actual reviews people have posted. It will take you time, but there is a TON of good information out there, you just gotta put some time in. No one is going to, or can, spoon feed you an answer because there are too many variables. All you're going to get in a thread like this is a totally random list of parts/names from every conceivable price point. Not everyone who buys or installs a coilover is equipped to actually review one. For many people, it's the first car they have had a coilover on, for others, they may have bought the car used and at 80k, 90k, or 100k their stock stuff was so shot that a set of SensaTracks might have made the car feel like the Porsche they like to think the car is. Skip the internet high fives of how their car 'handles on rails', or things like 'they are great' with their $600, $800 or $1000 coilovers. Really tells you nothing when you think about it. $1500 is not a small amount of money and you have the opportunity to get it right and actual derive a benefit from what you put in, or get it wrong, and then be like most everyone else who is convinced they made things better simply because they changed a part.
Old Feb 22, 2012 | 08:07 AM
SirSpeedyZ's Avatar
SirSpeedyZ
I mostly just pay attention to what Z1 performance posts and ask Z1NONLY questions (because I've seen his car and how it handles)
That's the best advice you can get OP
Old Feb 22, 2012 | 10:06 AM
Wise comments but unfortunately new members want one sentence approval of their preconceived notions. Installing coil overs on a street legal 350Z is going to miraculously turn it into a "race car?" Whatever. I am tired of offering sensible advise to these kids.
Old Feb 22, 2012 | 10:44 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
General advice for OP and others:
If all you care about is how low your car is and your budget is around $1000 go with Stance coilovers or something similar.
If you care about handling then generally stick to the coilovers that cost around $2k or more..if your budget is $1500 then buy a used set of $2k coilovers or a discontinued model.
If you care about handling but your budget is $1000 or below then stick to a upgraded shock/spring setup.
Old Feb 22, 2012 | 11:40 AM
braydo25
Garage is empty, add now
Figure 4 posts in 4 months we will never hear from braydo25 again. This is the new norm here. Create a thread and never return.
Old Feb 22, 2012 | 12:37 PM
Gsedan35's Avatar
Gsedan35
Thanks!
1.5" to 2" drop?
IMO I would recommend oem to -1.2". You'll be amazed on how many times you scrap and bang the underside of the car as you get closer to the 1" drop.
This is what I would recommend
Tokico DSK-512 shock and spring kit
Spring rates 375/375 (all linear) Drop 1"/1.5" $719
http://www.thezstore.com/page/TZS/PR...z11b01/23-3998
Hotchkis Sway bars $374
http://www.z1auto.com/prodmore.asp?m...ng&prodid=1345
Eibach rear camber arms with elongated toe cam bolts $155
http://www.z1auto.com/prodmore.asp?m...ng&prodid=2890
TOTAL $1248 (not including shipping)
Or
Eibach Pro-S coilover $1225
Direct copy of Kw Variant 1 coilover twin tube constrution, reuses oem upper shock mounts
Spring rates Front 485lbs to 525Lbs Rear: 240Lbs to 548Lbs (progressive springs)
Min and Max ride height Front: -.8”/-1.5” Rear: -.8”/-1.5”
http://www.z1auto.com/prodmore.asp?m...ng&prodid=3265
TOTAL $1380
I would only bother with front camber correction unless the numbers AFTER your alignment are so bad that you can justify spending $400-$600 for front correction. Just remember to use the oem factory front toe adjustment for toe in.
Old Feb 22, 2012 | 02:43 PM
n8dog11914's Avatar
n8dog11914
Originally Posted by Gsedan35
1.5" to 2" drop?
Or
TOTAL $1380
I'm surprised you recommended that Tokico spring / setup combination. I've heard mixed opinions.
Personally, I run Koni Yellows on revised springs. The setup performs and rides better than the Megan springs the previous owner had installed.
