Cutting Spring Mounts
Old Apr 14, 2012 | 11:58 AM
dPayne8540's Avatar
dPayne8540
Default Cutting Spring Mounts
I found some old posts about this back from 2007 but I figured I would make a new one to ask this question. I'm thinking about cutting a little off my spring mounts to drop my rear on my 2006 Z. Probably about a half inch. I have stock suspension. Will this be exactly a half inch drop for the back? Also, someone told me if you drop the back, the front is also gonna drop a little bit. Doesn't seem right to me. I figured someone could tell me yes or no on that too. Thanks.
Old Apr 14, 2012 | 12:33 PM
dkmesa350z's Avatar
dkmesa350z
It will lower the rear by however much you cut. Front will not change.
I cut half an inch from mine a couple years ago and have been happy with the stance.
Old Apr 14, 2012 | 12:58 PM
thisishk350's Avatar
thisishk350
It will drop by exactly the amount you cut, the springs will still compress the same so the only thing that will change is the amount of wheel gap. Just helped out a friend with his, its pretty easy, although access to a band-saw or something helps to get through the mount
Old Apr 14, 2012 | 01:17 PM
dPayne8540's Avatar
dPayne8540
I appreciate it! I wanted lowering springs but it's my daily driver and I already scrape on things so I think I'll be happy with this.
Old Apr 14, 2012 | 06:38 PM
beezee's Avatar
beezee
Scrape on things on stock suspension?. You would scrape 1/2 inch more then.
This mod looks even nicer when you add it to a moderate drop springs though.
Old Apr 14, 2012 | 07:08 PM
dPayne8540's Avatar
dPayne8540
Any suggestions on springs I should get?
Old Apr 15, 2012 | 10:55 AM
beezee's Avatar
beezee
Anything that will give up to 1 inch drop, then cut half inch to end up with about 1.5 drop in the back. You would love the look. You might need a fender roll depending on rim and tire specs. I had tokico springs and 1/2 inch cut for a while. Looked nice but I had to take the cut mounts off and go back to original because I did not want to go through the fender roll stuff further.
Old Apr 15, 2012 | 08:19 PM
Bmurray350z's Avatar
Bmurray350z
I'll recommend Tanabe GF210 springs
My Z with Tanabe GF210's and spring mounts cut:
Old Apr 15, 2012 | 09:55 PM
ronn1's Avatar
ronn1
That drop looks fuggin ****!
Old Apr 16, 2012 | 04:35 AM
beezee's Avatar
beezee
^Looks pretty good
Old Apr 16, 2012 | 06:04 AM
Bmurray350z
Thanks. Still saving up for coils tho.. i wanna slam it
Old Apr 18, 2012 | 08:51 PM
13ino13's Avatar
13ino13
I lowered my car today with Swift Sport Spec R springs and also cut the spring mount. I didn't notice anymore of a drop in the front but it makes sense if it did. Every time I raise my rear end from the differential, the front also raises, and that's my logic behind it. Although if the front also dropped, it was probably only a few mm. Again, nothing noticeable in the front, but definitely evened up the tire gap a bit more.
Old Apr 19, 2012 | 04:03 AM
Deteria's Avatar
Deteria
Will this affect the camber?
Old Apr 19, 2012 | 04:40 AM
beezee's Avatar
beezee
Just the .5 cut will not. However if you add that to lowering springs, It could.
Any total drop of more than 1 inch will almost certainly affect camber
sales@czp
Sep 23, 2019 03:30 PM
