Torque Specs Coilovers/Toe Arms/Camber Arms
Old Apr 18, 2012 | 06:33 PM
TeegsMR's Avatar
TeegsMR
Default Torque Specs Coilovers/Toe Arms/Camber Arms
I've been searching through this forum for a while looking for the torque specs for suspension parts on my Z. I will be installing BC true style coilovers, SPL rear toe arms w/lockout wahers, and camber arms. If anyone has these specs or a link to these specs please post them up!
Thanks in advance!
Old Apr 18, 2012 | 10:35 PM
terrasmak's Avatar
Drop by and hit up Roger at Paladin Advanced, he can let you know. Most of us just go tight as hell, just like the factory does it.
Old Apr 19, 2012 | 07:09 AM
brandon7219's Avatar
brandon7219
the torque is german torque: goodentight
Old Apr 19, 2012 | 10:22 PM
TeegsMR's Avatar
TeegsMR
LOL Thanks
Old Apr 19, 2012 | 10:47 PM
taywan's Avatar
taywan
You can over-tighten also so be careful.
Old Apr 20, 2012 | 03:50 AM
TeegsMR's Avatar
TeegsMR
Exactly......thats why I want to get the correct torque specs Seems like most who do their own installing don't use a torque wrench?
Old Apr 20, 2012 | 04:08 AM
sry110's Avatar
sry110
For MOST things, I use a torque wrench and adhere to the published specs (plus maybe a little nudge past the click just to be sure). But when I installed my coilovers, somehow I convinced myself it was OK to just tighten everything by feel. Probably because I ran into the same problem you're having, which is that the various torque values are not readily available without having a shop manual. For whatever it's worth, I didn't hear any weird popping/clicking/etc. sounds or have any other obvious problems after doing it myself and getting everything "tight enough".
Also, I used a standard 1/2" drive ratchet (Craftsman, maybe 9" long?), to give you an idea of the amount of leverage I had on the nuts/bolts. Use a breaker bar to get everything loose (if needed), but use something with a shorter lever arm to tighten everything back up.
Old Apr 20, 2012 | 06:56 AM
terrasmak's Avatar
I turn wrenches for a living, I know torque to feel pretty dam well.
Old Apr 20, 2012 | 07:56 AM
TeegsMR's Avatar
TeegsMR
Ya I know what ya mean....I turn wrenches for a living too! Suspension parts just worry me a bit, so I was trying to give myself a piece of mind thats all. I have installed coilovers two time before on my previous cars and never had a problem........just thought I would try it the correct way thats all.
EnjukuRacing
Sep 30, 2015 06:55 AM
