Akebono caliper with COZ bracket pad contact issue
Old Apr 22, 2012 | 05:18 AM
e30cabrio's Avatar
e30cabrio
Default Akebono caliper with COZ bracket pad contact issue
I have had the Akebonos from a G37S on my Z for over a year. Initially I had eBay brackets and Adams rotors. I got a steal on a pair of DBA 2 peice rotors and just in case figured I'd get the COZ brackets.
There was a bit of untouched rotor before, now it is much larger.
Old:
New:
Passenger side
Driver side:
The back side is about the same as the old rotor.
My question is does anyone know of a pad that extends down towards the hub further, currently I have EBC Red Stuff pads.
Thanks
Old Apr 22, 2012 | 06:02 AM
SirSpeedyZ's Avatar
SirSpeedyZ
I would think that all pads would be the same size and one shouldn't extend farther than another, but I could be wrong.
Is it possible to adjust the bracket so you coverage is more even? It seems that's where you're problem is.
Old Apr 22, 2012 | 06:04 AM
e30cabrio's Avatar
e30cabrio
Nope, the bracket is where it goes and there is nothing I can do about it.
I might put the eBay back.
Old Apr 22, 2012 | 06:05 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
you swapped rotors. One may have a larger disk than the other giving you the illusion that the pad is not covering as much as with the old bracket.
Measure the rotors and the contact area.
Old Apr 22, 2012 | 06:11 AM
e30cabrio's Avatar
e30cabrio
I'll measure the old rotor later but they look the same size to me.
Old Apr 22, 2012 | 06:30 AM
SirSpeedyZ's Avatar
SirSpeedyZ
Everything else being the same, it's gotta be the bracket then
Old Apr 22, 2012 | 06:34 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Swept area on DBA looks noticeably wider than swept area on old rotors. That's the measurement that matters. In other words looks
Like DBA has more disk, less hub
Old Apr 22, 2012 | 07:06 AM
e30cabrio's Avatar
e30cabrio
Thanks Adam. Do you think it is a problem having so much disk untouched?
I am concerned it is not heating up as designed and that that may cause warping.
Old Apr 22, 2012 | 07:30 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
that is what I was trying to say.
Old Apr 22, 2012 | 09:07 AM
e30cabrio's Avatar
e30cabrio
^Thank you too!
Old Apr 22, 2012 | 12:53 PM
ronn1's Avatar
ronn1
Many aftermarket rotors use *generic* discs to start (to fit many applications as possible) and so you may have a LARGER potential SWEPT area. That is evident in your picks. Rotors are same size, but the pads will leave a larger unswept surface on the new rotors. Gives the illusion of pads not being properly placed on the disc....they are.
Old Apr 22, 2012 | 12:56 PM
e30cabrio's Avatar
e30cabrio
Coz responded to my email. He said Nissan paints that area to keep them from rusting and it's normai.
Thanks for the input guys!
Old Apr 22, 2012 | 01:02 PM
ronn1's Avatar
ronn1
I just put on Powerslot rears and had the same thing. I painted the unswept area with Krylon BBQ and Stove paint Black (1200*F). Looks great. I painted them ON THE CAR..using masking tape to cover calipers and swept area. You don't need to get swept area perfect (round), since pad will sweep extra paint off. Just make sure to paint a little beyond (1mm) non swept (rusted!) ring.
Old Apr 22, 2012 | 01:04 PM
e30cabrio's Avatar
e30cabrio
Great idea. Thanks.
Old Apr 22, 2012 | 01:08 PM
ronn1's Avatar
ronn1
Great idea. Thanks.
I see you have special screws on the hat...I would tape over those..it's ok if you get some black on the hat, since it's also black and paint won't show. my hats were already black and I didn't bother to tape over em.
Old Apr 23, 2012 | 02:04 PM
e30cabrio's Avatar
e30cabrio
Thanks
Old Jun 16, 2012 | 08:57 PM
ntwillie1's Avatar
ntwillie1
speaking of the ebc red pads, do yours squeel? Mine sound like a pig at almost every stop. Thanks.
Wil
Old Jun 16, 2012 | 09:06 PM
ronn1's Avatar
ronn1
Wil
Put on Stop techs>>>done.
Old Jun 18, 2012 | 07:09 PM
e30cabrio's Avatar
e30cabrio
No noise ever.
350z82
Oct 1, 2015 06:25 PM
