Can you tell me if my Helper Springs are installed correctly
Old May 26, 2012 | 06:00 PM
(ZzzzzZ)'s Avatar
(ZzzzzZ)
Default Can you tell me if my Helper Springs are installed correctly
Hey guys,
I am not too familiar with helper springs, but it came with my coilovers. Is this installed correctly? The helper spring is wound up so tight, I doubt it does anything for rebound support. On the website, there are a few pics of the helper spring installed on TOP of the spring, but I got these installed by shane from g35 and hes a reputable guy so not sure which is right. Plz let me know, thanks
Attached Thumbnails Can you tell me if my Helper Springs are installed correctly-imag0128.jpg   Can you tell me if my Helper Springs are installed correctly-imag0129.jpg
Old May 26, 2012 | 08:38 PM
terrasmak's Avatar
Nope, either not installed right or not needed.n
Old May 26, 2012 | 09:28 PM
(ZzzzzZ)'s Avatar
(ZzzzzZ)
should i throw them up top of the springs like the pics on the website?
Old May 26, 2012 | 11:52 PM
herrschaft's Avatar
herrschaft
^I'm not a suspension expert but I doubt it would matter.
Old May 27, 2012 | 12:52 AM
konrad's Avatar
konrad
it doesnt matter if they are on top of the spring or the bottom, they still compress the spring the same way and the same amount.
Old May 27, 2012 | 08:00 AM
terrasmak's Avatar
If they are fully compressed with preload, you do not need them. Remove them , simple and easy
Old May 27, 2012 | 10:26 AM
(ZzzzzZ)'s Avatar
(ZzzzzZ)
So the helper springs dont do anything and they charge more for them??
Old May 27, 2012 | 12:11 PM
03threefiftyz's Avatar
03threefiftyz
Does the threaded sleeve go up to the top of where the helper is?
Old May 27, 2012 | 12:43 PM
ronn1's Avatar
ronn1
Helpers keep spring preload at desired levels....preventing spring from getting loose and possibly dislodging from perch on UNWEIGHTING suspension. This occurs when tire drops and lifts (or almost does) off the ground. If spring is tight when tire does this (especially with coils that don't require changes in spring load with height adjustments), then helper serves no pupose.
Old May 27, 2012 | 05:51 PM
03threefiftyz
Helpers come into to play big time when you run stiff springs and relatively short travel shocks (and non-shorted more so). I use them because an 8" spring is too short for my motons on full extension. I don't use a rear sway bar most of the time and I pick the front wheel up off the ground quite a bit. This would unseat the spring if I didn't have helpers on. Race springs generally come in 5-8" lengths (though there are more) in 25-50lb intervals.
Pic below shows what I mean:
Old May 27, 2012 | 09:32 PM
djwatts's Avatar
djwatts
Would helper springs be good for daily use, as far as comfort and performance? I'm installing the Stance Gr+ Pro with helper springs and will be doing a mild drop. Also helper spring are only for rear correct?
Sorry to thread jack but I think this might help op as well.
Old May 28, 2012 | 02:58 AM
03threefiftyz
They really have no bearing on comfort or performance. You still ride on just the main spring.
Old May 28, 2012 | 06:53 AM
djwatts's Avatar
djwatts
So why are vendors and companies making a huge selling point on having these
? I'm having mixed reviews as these are good and others saying they are not?
Old May 28, 2012 | 08:52 AM
terrasmak's Avatar
Sometimes you need them , sometimes you don't . Depends on your spring rate and ride height.
Depravity
Oct 1, 2015 04:49 PM
