Brakes won't depress...ugh
Old Jun 13, 2012 | 11:33 AM
Kimosabe's Avatar
Kimosabe
Default Brakes won't depress...ugh
So here is a fun one.
Yesterday morning, I was reversing out of my driveway, and as pressed the brake, the pedal wouldn't budge. There would be a slight bit of braking power, but nothing I would trust my life with.
After maybe 30-40 seconds of driving at low low speeds, the brake pedal and power was back to normal. The car was fine all day. And I only drove it again after 8 hours when i left work and the pedal was still working fine.
It wasn't until this morning where I had the exact same problem. Brake pedal won't go down or engage brakes. After the same duration, they were fine. And they remain fine during the day.
What is happening?
Thanks for any input.
Old Jun 13, 2012 | 02:23 PM
Neimad's Avatar
Neimad
Check the brake booster line with the check valve in it, near the battery. The pedal feels the same as when the engine is off?
Old Jun 13, 2012 | 03:04 PM
Chebosto's Avatar
Chebosto
so you step on the pedal as hard as you can and nothing happens, right?
+1 on brake booster check..
Old Jun 13, 2012 | 04:20 PM
laurentj23's Avatar
laurentj23
Did you check the brake fluids? And of course the brake booster. Check for leaks on the MC and all 4 wheels.
Old Jun 13, 2012 | 08:16 PM
Kimosabe's Avatar
Kimosabe
It does feel like the car is off basically. I press, and there is full resistance. Nothing gives. I checked for leaks, nada. What am I looking for on the brake booster and MC? I'll check my fluids tomorrow as well.
Like I said, it goes away after 30 seconds of driving. Any idea what could be happening?
Old Jun 16, 2012 | 07:09 PM
User 42426's Avatar
User 42426
i might have a similar situation, whats the break booster?
Old Jun 17, 2012 | 08:49 AM
Neimad's Avatar
Neimad
Big round housing on the firewall that the master cylinder mounts to, uses engine vacuum to help you push the brake pedal.
Old Jun 19, 2012 | 09:59 AM
zakmartin's Avatar
zakmartin
Here ya go.
