Stock Brake Pad Replacement Suggestions
Old Sep 15, 2012 | 08:14 AM
mnd7775's Avatar
mnd7775
Default Stock Brake Pad Replacement Suggestions
Hey guys,
So I've looked through some threads, and mostly I see people upgrading their brake pads to very high end stuff. I am not looking to upgrade my brake pads, but rather replace with good quality ones. If I go to NAPA and get ceramic brake pads would I see a good quality product? or is that something that people had bad experience with? In particular I was looking at these here:http://www.napaonline.com/Catalog/Ca...18B_0319671542. Any input would help, thnx!
Old Sep 15, 2012 | 10:18 AM
Voboy's Avatar
Voboy
Try it and report back. My preference has been OEM or Stoptech.
Old Sep 15, 2012 | 10:26 AM
Z1NONLY's Avatar
Z1NONLY
HPS pads are very gentle on rotors, don't dust much, handle heat a little better than stock pads, and seem to last for more miles too.
The only downside is slightly less bite than stock pads.
Old Sep 15, 2012 | 01:01 PM
User 42426's Avatar
User 42426
hps, hawk, akebono,, stoptech
Old Sep 15, 2012 | 07:29 PM
2000atlanticgt's Avatar
2000atlanticgt
Hard to beat the price of the Stoptech 309 street pads. I am on my second set and have been happy with them for both HPDE and daily driving. You can find them on Tire Rack, that is where I ordered my last set.
Old Sep 15, 2012 | 07:35 PM
SponGer's Avatar
SponGer
Yeah, the Stop Tech 309 pads are good. The only thing I don't like is the amount of brown dust they emit. Ordered mine over the phone from R1 Concepts and got a real good deal because I told then I was a forum member.
Old Sep 17, 2012 | 09:56 AM
mnd7775's Avatar
mnd7775
Well I decided to wait and ordered a set of Stoptech 309s and drilled/slotted rotors all the way around. First time working on brakes ever so hopefully it will be pretty easy since I will not be doing SS lines. Wish me luck!
Old Sep 17, 2012 | 10:26 AM
Voboy's Avatar
Voboy
It's very easy... impact gun or a good breaker bar should pop the brake caliper bolts off easily. The hardest thing is probably getting the pads and small pad brackets back in caliper. They tend to keep falling off before you can get the caliper swung back in place!
Old Sep 17, 2012 | 11:13 AM
raf84ny's Avatar
raf84ny
Good luck. Take your time and you'll be fine.
Old Jun 24, 2013 | 04:57 AM
MB33's Avatar
MB33
Went to midas to get a quote to replace my front an rear set brake pads. They said it will be 380 dollars installed. I left the place!
Old Jun 24, 2013 | 07:52 AM
stuartc323's Avatar
stuartc323
https://my350z.com/forum/brakes-and-...rake-pads.html
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
samansharif
Sep 25, 2015 12:31 PM
