just installed ceramic hawk pads
Old Oct 16, 2012 | 11:17 PM
Marcodiaz93's Avatar
Marcodiaz93
Default just installed ceramic hawk pads
i installed these brake pads about 200 miles ago and just now they are starting to make some noise. i didnt resurface my rotors so im wondering if that is why they are squeaking. on my oem pads it looked like there were two sets of pad shims. i only installed the first pair on the pads. i cleaned them and then put the grease that came with the pads on. why could they be squeaking? it is not all the time, only sometimess.
Old Oct 17, 2012 | 05:27 AM
zswickliffe's Avatar
zswickliffe
My Centric ceramic pads took about 1k miles to quiet down. If I recall, they were really quiet at first then they started making an almost metal on metal noise when they would heat up. After another thousand or so miles (where I'm at today) I haven't noticed any noise that I can think of in a while. Give it some time, these ceramic pads take a while to bed-in.
Old Oct 17, 2012 | 05:35 AM
JERZ350's Avatar
JERZ350
Sometimes pads just squeak, almost like a break-in period. Do they squeak all the time while driving without braking? Or only when braking. Do they stop squeaking during HARD braking or only under light braking.
Old Oct 17, 2012 | 05:42 AM
VO...'s Avatar
VO...
Administrator
Yep, all the years I've been here I've heard this about these pads. I remember installing my new Stop Tech BBK. It came with aggressive race pads. They squeaked like a SOB. After exhausting all options(created an extensive write-up), I decided to swapped them out. Now I never have problems.
BTW, alot of diehard brake enthusiast will tell you it's "recommended" to resurface your rotors everytime you change pades, but it's not. You really only need to resurface them if they have any notches or slight warping. You'll know, because everytime you apply the brake at highway speed, the steering wheel will shake...
Old Oct 17, 2012 | 07:28 AM
terrasmak's Avatar
Bed the pads in
Old Oct 18, 2012 | 07:43 PM
Suwaidi's Avatar
Suwaidi
https://my350z.com/forum/brakes-and-...ur-brakes.html
Old Oct 22, 2012 | 05:41 PM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
I've heard that Hawk pads can be dusty and noisy. Drive with them a bit more and report back!
Old Oct 22, 2012 | 09:59 PM
Duckeee's Avatar
Duckeee
i don't like my hps's at all with my brembo. at first i thought it was good. then i realized it builds dust pretty quickly and squeaks randomly.
Old Oct 22, 2012 | 10:21 PM
SE5spd's Avatar
SE5spd
HPS are awful I'd rather rock stock.
Old Oct 22, 2012 | 11:14 PM
kuyo's Avatar
kuyo
so is it true that hawks pads create a crap load of brake dust like said earlier? I had a friend who used hawks and the brake dust build up was crazy on his car..That steered me away from them since I don't wanna clean my wheels every 3 days
Old Oct 22, 2012 | 11:19 PM
SE5spd's Avatar
SE5spd
If you dont plan on ever road racing stick with OEM Nissan pads.
Old Oct 23, 2012 | 07:39 AM
Duckeee's Avatar
Duckeee
i had noticeable brake fade with the hps's on my stock brembos..
Old Oct 23, 2012 | 08:07 AM
KNS Brakes's Avatar
KNS Brakes
The Hawk Ceramic Pads are good low dust pads, the performance for them is below OEM. The HPS are good pads as well just around OEM, if you want something to have better bite and better fade resistance, try Stoptechs, the only downside is a little bit of dust.
-Nick
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
