carbotech eating up rotors
Old Dec 21, 2012 | 06:44 AM
JDMStanced's Avatar
JDMStanced
Default carbotech eating up rotors
hi, i have carbotech ax6 for both front and rear on non brembo.
Aren't they suppose to be rotor friendly? I haven't checked the rear rotors but the front rotors are worn down a lot.
Old Dec 21, 2012 | 10:16 AM
KNS Brakes's Avatar
KNS Brakes
Vendor - Former Vendor
How much pad do you have left? What do you use the car for?
-Nick
Old Dec 21, 2012 | 10:31 AM
JDMStanced's Avatar
JDMStanced
-Nick
it's half the thickness of the back plate.
i mostly used for DD. maybe took it to drifting once..
Old Dec 21, 2012 | 10:36 AM
KNS Brakes's Avatar
KNS Brakes
It's going to wear some - rotor friendly doesn't mean no rotor wear. AX6 are semi- aggressive.
But what is the rotor thickness - you need to measure them to see the wear.
If you pads are down to 3 mm - time to order. That's getting thin.
Old Dec 21, 2012 | 10:48 AM
03threefiftyz's Avatar
03threefiftyz
As long as the rotor wear isn't uniform, I wouldn't worry.
Old Dec 21, 2012 | 11:14 AM
JDMStanced's Avatar
JDMStanced
if you look closely at the pic i attached, you can see the metal piece that surround the rotor is exposed.. its not the backing plate.
i never used rotors for this long .. it doesnt look normal to me..
Old Dec 21, 2012 | 06:18 PM
zeroaccessinc's Avatar
zeroaccessinc
Default Send a quote
Brembo Front / Rear need pads/rotors prefer x-drilled/slotted 2 piece. and whatever pads best already have lines...
Thanks
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
SanmarinoZ
Oct 21, 2015 10:04 AM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
