metalllic clunk sound when going over small bumps
Old Feb 12, 2014 | 06:43 AM
Z33Garage's Avatar
Z33Garage
I have this issue with my 05 Z with stock shocks/ springs. It clunks whenever I take a speed bump. I have greased just about everything to no avail. The endlinks look good on mine too, no loss of grease.
Old Feb 12, 2014 | 07:21 AM
Nismo350z#0310's Avatar
Nismo350z#0310
Originally Posted by 3oh5z
well to be frank, STANCE and any other coilover setup is going to produce noise.period. They aren't made to be comfy daily driven products. But to answer your question, yes you can go very low with this setup....
says who?
installed correctly and proper supplemental parts there will be no noise.
If you have noise it is not the quality of the coilover but the install job or other parts failing due to being lower / stiffer suspension. i.e. bushings, swaybar endlinks, and overall tightness of the coilovers. My first install I didn't tighten the coilvoer enough and it would clunk. Tightened it properly, installed endlinks and adjusted it all properly and there is zero noise.
Anyone who says it's clunking didn't do something right.
Old Mar 8, 2014 | 02:50 PM
bizarrosZ's Avatar
bizarrosZ
Default Getting a clunk sound
Hey everyone , been trying to find out what's wrong with my car, I have an 06 Z, and recently I've been having a "clunk" sound when stepping on the brakes, it's coming mainly from the front passenger side,, I have a thread on here I just posted , "can any Z family members help me out" , so I'm sorry for going all over the place trying to find answers..
So someone recommended I change the lower control arm, since that's a main cause sometimes, changed it and put a new one on, it stopped my wheel from wiggling a lot, but now I still have that clunk sound, maybe I need to replace the driver side lower control arm aswell.. I also noticed my ball joint all greased up and it looks like it's worn out, could that be an issue on why it clunks aswell?
Attached Thumbnails metalllic clunk sound when going over small bumps-image.jpg
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
