Rear camber kit questions
Old Jun 21, 2013 | 07:06 PM
parrotheadmatt's Avatar
parrotheadmatt
Default Rear camber kit questions
Hello all,
I have been searching through threads about what is the best brand to get and so far I have seen good things about the Kinetix brand. My question is before I purchased my car an alignment was performed and I was told the rear camber was just barely in spec, but moved on the line of "green". I don't know hard numbers, but this week I replaced my tires the fronts were wearing fairly even the rears had the dreaded inside wear. I do alignments all the time and I know after tweaking the rear it can throw the front way off. I'm hoping to just get by with the rear camber kit and wanted to know if many people were only needing the rear camber kit or if they were finding out they needed toe kits too?
Last week I was machining my front rotors due to brake judder and found my tire like this:
The PO stretched the front tires on the rim which I hate so I put a wider tire on it. My theory is I ran over a pothole and it rolled the tire which pinched the rubber causing it to rip but not puncture the tire.
Old Jun 21, 2013 | 07:15 PM
Bmurray350z's Avatar
Bmurray350z
Get the SPC arms and toe bolts just to be sure everything including toe gets back into spec. Toe is what eats up tires.
Old Jun 21, 2013 | 07:27 PM
parrotheadmatt
Supposedly the toe is fine and the only thing that was out was the camber so I figured camber would have caused this I know toe will eat a tire faster than camber will. lol I'll be sure to get it all into spec. I know lowering/bigger rims throws the angle lines way off I just want everything to be even as far as still having good cornering performance with tire wire.
Old Jun 21, 2013 | 08:26 PM
ronn1's Avatar
ronn1
I only needed to add rear camber arms to bring my lowered car into spec ( -2.0) The TOE could be brought in spec with stock toe bolts . I'm lowered about 1 1/2 in rear.
Tire damage was prolly from stretched tires.
Old Jun 21, 2013 | 09:38 PM
X.et's Avatar
X.et
Get spc camber kit with toe bolts and make sure you elongate the toe bolt holes so you can actually get the adjustment you need.
Old Jun 22, 2013 | 06:24 AM
stuartc323's Avatar
stuartc323
It was the tire strecthing and you hit something or you have some negatice camber but you need to just get the SPL bolts or the SPC bolts and it will bring everything back into line, just like everyone else said.
Old Jun 22, 2013 | 09:44 AM
parrotheadmatt
Thanks for the advise ill be getting me some new parts and modifying my z woop woop!
Old Jun 22, 2013 | 03:13 PM
DCJodon's Avatar
DCJodon
Camber did not do that to your tire.
Old Jun 22, 2013 | 03:43 PM
parrotheadmatt
the tire I posted is my front tire it was wearing fine the hole was made from a pothole
Old Jun 22, 2013 | 09:28 PM
stuartc323's Avatar
stuartc323
Ouch that was a hell of a pothole ^
Old Jun 24, 2013 | 07:19 AM
driftsucky's Avatar
driftsucky
None of that has anything to do with camber. I've got -7 and I have friends running -12 and don't go thru tires. OBVIOUSLY the wear is uneven, but then you just switch the sides. Badabing badaboom. TOE eats up tires. If anybody says that's camber, punch'em in the knutz immediately and walk off while drinking a chocolate milkshake.
To answer your question, SPC makes a rear camber kit for cheap. Do it up.
Old Jun 26, 2013 | 05:16 PM
parrotheadmatt
lol I agree with you sir the spc kit will be here tomorrow hopefully I'll have time after work Friday to install it.
Juztin
Nov 22, 2015 07:03 AM
bcoffee20
Nov 19, 2015 06:39 PM
emooheo
Oct 14, 2015 08:58 AM
CJs_Z33
Sep 18, 2015 12:06 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
