Air suspension Toe adjustment
Old Jun 23, 2013 | 11:02 PM
kazeron's Avatar
kazeron
Default Air suspension Toe adjustment
I'm going air ride on my Z, i need help figuring out how to adjust toe in the rear since i now have to get rid of my toe arm and replace it for the bucket for the bag to sit in. Information would be greatly appreciated, dont give me that "Never do air on a Z" bull.
Old Jun 24, 2013 | 02:32 AM
nismo4life11's Avatar
nismo4life11
When you put the spring bucket back on you'll just use a SPC Toe bolt kit. It should give you enough adjustment to get your toe within spec at your chosen ride height. You will have your ride height setup either through using specific air pressures in the bags or if you opt for a self leveling system it will be setup through there.
Old Jun 24, 2013 | 06:08 AM
kazeron's Avatar
kazeron
The toe bolt won't have enough adjustment to bring my toe back into spec, I need something like the spl mid link but that arm is designed to where it can't use a bag
Old Jun 24, 2013 | 06:52 AM
nismo4life11
Even after you dremel out the hole to make it longer you still dont have enough adjustment to get your toe into spec? I have no idea then I'm on air with the SPC camber and toe kit and at my ride height im within spec on my toe, only my camber is off due to my fitment.
Old Jun 24, 2013 | 07:07 AM
kazeron's Avatar
kazeron
How much camber are you running at ride height and aired out?
Old Jun 24, 2013 | 10:10 AM
nismo4life11
-3 at ride height no idea what it is fully airred out but my normal ride height isnt slammed either I live in CT cant ride around airred out all the time without completely destroying the car. Heres a pic of my ride height there are pics of it airred out in my garage album thing.
Old Jun 1, 2015 | 01:53 PM
SlammedZ60's Avatar
SlammedZ60
So was anything ever figured out with this? I'm going through the same problem.
Old Jun 1, 2015 | 05:57 PM
terrasmak's Avatar
SPL Spring bucket arm may work well for the application
Old Jun 1, 2015 | 10:23 PM
SlammedZ60's Avatar
SlammedZ60
Most bags will not fit in the SPL spring bucket. The SPL spring bucket was designed for a lowering spring, not a bag.
Old Nov 10, 2019 | 11:07 PM
TGMcCoy's Avatar
TGMcCoy
Bumping this very dead thread as I have the same issue as op..
Wondering if the hold for the toe bolts can be elongated further than the template allows? Or other ideas.. Thanks!
350Z_Al
Oct 29, 2020 07:44 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
