compression rod install question
Old Sep 17, 2013 | 02:45 PM
redpearl99's Avatar
redpearl99
Default compression rod install question
So I've looked over all the DIY threads and I've noticed that some suggest tightening all the bolts when the car is on the ground while others say nothing about this. The FSM also seems to say that the bolts should be tightened when the wheels are on the ground.
So am I reading this correctly???? how am I supposed to get under the car and tighten everything when the car is back on the ground??? doesnt seem right
Old Sep 17, 2013 | 03:08 PM
Bmurray350z's Avatar
Bmurray350z
4 post lift?
Old Sep 17, 2013 | 04:06 PM
redpearl99's Avatar
redpearl99
doing this under jack stands
Old Sep 17, 2013 | 04:15 PM
Bmurray350z
Yes. You need a 4 post lift to tighten those bolts with the wheels on the ground.
Old Sep 17, 2013 | 04:21 PM
terrasmak's Avatar
SPL or Whiteline bushings, this will not apply.
Old Sep 17, 2013 | 06:32 PM
redpearl99's Avatar
redpearl99
oem compression rods. So should i just jack up the front axles when tightening the bolts?
Old Sep 17, 2013 | 06:33 PM
Bmurray350z
that or you could get some of those rhino ramps or whatever they're called.. or take it somewhere that has a 4 post lift. lol
Old Sep 17, 2013 | 06:50 PM
redpearl99's Avatar
redpearl99
i refuse to ever pay a mechanic for anything. if i've taken apart my engine myself im sure i can deal with a compression rod. so i guess i can just jack up the axles when tightening the bolts
Old Sep 17, 2013 | 07:01 PM
Bmurray350z
for someone who has taken an engine out,etc.. supposedly, you sure are having a hard time with these compression rods and how you're supposed to do it lol.
Old Sep 17, 2013 | 07:26 PM
redpearl99's Avatar
redpearl99
I have a tenancy to worry about the slightest things my friend lol
Old Sep 17, 2013 | 08:26 PM
freddys 350z's Avatar
freddys 350z
i jacked up the spindle to line up the hole. this was with whiteline bushings.
Dr.Paulyy
Jul 29, 2019 07:45 AM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
bcoffee20
Nov 19, 2015 06:39 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
