change a stud
Old Oct 29, 2013 | 02:52 PM
swilson1120's Avatar
swilson1120
Default change a stud
Need to change a stud in my rear hub. how do you get the rotor off? do you need to take the axle nut off? looking for quick help thanks
Old Oct 29, 2013 | 03:39 PM
superlim9's Avatar
superlim9
you have to remove the caliper mounting bracket before you can take the rotor off
Old Oct 29, 2013 | 03:45 PM
Bmurray350z's Avatar
Bmurray350z
remove caliper bracket & make sure e brake is not up. may have to hit the rotor several times with a rubber mallet. then it'll come right off.
Old Oct 29, 2013 | 03:54 PM
Waiz's Avatar
Waiz
Someone was asking me about this yesterday, here is the DIY regarding how to install extended studs but also works for installing normal studs
https://my350z.com/forum/body-interi...-friendly.html
Old Oct 29, 2013 | 04:14 PM
swilson1120
Thanks guys i figured it out. Never using aluminum lug nuts again lmao
lapham3
Oct 7, 2022 03:15 PM
