Noise in rear suspension help!!
on
My car has been making creaking noises from the back end of the car. I have been told it may be bushings that are going bad, but wanted input from anyone who may have had/are having this same problem
Had similar sounds on my vintage 2003 starting 'bout 100k miles. Little squeaks when applying brakes - turn out to be rear bearings were gone. Replaced left hand first then couple k miles later the right. My mileage is mainly highway, couple of track runs but no driver education events.
I don't think mine is the axles, because with the windows down and creeping over speed bumps the sounds still sounds like it is coming from the inside shock towers. Not from outside or lower. Im leaning more towards shocks, the shock's upper mount, or the hatch possibly. And braking has nothing to do with it. just bumps
on
This sound is definitely not brakes or wheel bearings. more of a worn out bushing, or suspension problem. Really would love for someone to have fixed this already, not looking to shell out the money for shocks when it could be money poured into the engine instead!
Possibly the gasket between the upper shock mount and the shock tower, parts #6 and #8 seen here;
http://www.nissanpartswarehouse.com/...iagram=3714390
See this thread:
https://my350z.com/forum/maintenance...noise-fix.html
Post #54:
https://my350z.com/forum/maintenance...in-rear-3.html
Site is a great source for information.
See this thread:
Post #54:
I totally understand. No one wants to spend unnecessarily. Honestly though, $100 is chump change for some peace of mind.
FYI, after changing out the endlinks, there is no noise while driving, but the rear still creak slightly on steep driveways. Next up is new gasket and shock mount.
on
I just finished replacing the endlinks. I wont let my car touch snow so i wont find out if it was the problem until spring, but one endlink seemed to be destroyed for sure, felt like there was no grease in it at all. I'm 99% convinced that was my problem.
