Z1 Motorsports Brand Brembo Rotors
Old Feb 12, 2014 | 07:21 PM
Ljt350Z's Avatar
Ljt350Z
Default Z1 Motorsports Brand Brembo Rotors
Any feedback out there regarding these rotors? I'm in the market for some new rotors for my brembos. Not wanting to break the bank. My Z is just a daily driver, no track, just to and from work.
Thanks
Old Feb 12, 2014 | 08:11 PM
BY350z's Avatar
BY350z
If your not tracking your car then there's no need to spend a lot on rotors and pads...just go to your local autozone or oreillys and pick up some plain rotors
Old Feb 12, 2014 | 09:14 PM
zswickliffe's Avatar
zswickliffe
Check out my thread on Rotorpros' rotors. Great company to support that helps out forum members...
https://my350z.com/forum/brakes-and-...ke-rotors.html
Old Feb 13, 2014 | 09:05 AM
RedUzziJDM's Avatar
RedUzziJDM
I assuming you want some rotors that complement your car and not for performance. If that's the case just go with some nice looking Ebay rotors. But BEWARE it's ebay.
Old Feb 13, 2014 | 09:59 AM
allshownogo's Avatar
allshownogo
you state you don't want to break the bank, not for track use, and a DD = trip to your local nissan parts dept and go with OEM.
Old Feb 13, 2014 | 01:09 PM
Ljt350Z's Avatar
Ljt350Z
I just went to napa and picked up a set of fronts and rears. $92.82 a pair fronts and $65.32 a pair rears. Using my employee discount. These were their "ultra premium" rotors. Thanks guys for the input.
Old Feb 22, 2014 | 12:37 AM
DissFoo's Avatar
DissFoo
Not sure if you installed your rotors yet but I have them, bought them last month, got a really good deal from Jon at Z1, rotors, pads, ss lines and fluid. Didn't end up using the ss lines. Looks very clean with the Brembos. I bought the Stoptech pads, The hawks i was going to get, Jon recommend i didn't because i don't track my car. I can send you a pic if you want to see what it looks like.
Old Mar 5, 2014 | 03:13 AM
Ljt350Z's Avatar
Ljt350Z
Are you having any issues with your Brembos? I just installed them but my first initial brake sounds like the brake pads are knocking against the rotor. But when I get to driving with normal stop and go, the knock disappears. My research has me going back and greasing up the caliper pins. Plus it seems like the car runs differently.
Old Mar 5, 2014 | 03:17 AM
travlee's Avatar
travlee
Master
kinda sounds like the rotor isnt seated properly or something. i would take them off and double check everything and reassemble,
if you havent checked out the dfw group meets section, we are meeting at bone daddys grapevine on the 15th..... by350z if you are interested sign the sheet and come out
Old Mar 5, 2014 | 04:18 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Did you re-install the shims?
Old Mar 5, 2014 | 07:00 AM
Ljt350Z's Avatar
Ljt350Z
Yes, the pads I got, the shim had and adhesive backing, they also didn't come with grease. One of my trouble shooting steps was to grease the caliper pins and pad shims. Is the wear indicator on the pad suppose to be in the inside or outside of the rotor? I'm a novice when it comes to DIY on cars.
Old Mar 6, 2014 | 08:08 AM
Ljt350Z's Avatar
Ljt350Z
Yesterday I lubed up the pins. Then I used the motive bleeder. Had air pockets come out of all bleeders. I notice that my rear calipers do not have the oem hard line. I bought the Z1 lines that stated for these to work the oem hard lines need to be used. Not sure why my mechanic did not use them. But lubing and bleeding did not make the problem go away. I'm going to install the hard lines this weekend.
Old Mar 7, 2014 | 09:51 PM
DarkCreep's Avatar
DarkCreep
Youre only driving to and from work??
Make sure to get the most expensive rotors and stickiest pads money can buy. You never know when a cat will jump in front of your car and youll need to stop on a dime.
Old Mar 7, 2014 | 10:17 PM
Ljt350Z's Avatar
Ljt350Z
As long as I get a quick pump, it will stop on a dime.
Old Mar 7, 2014 | 10:37 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
I don't know how to take this post. However I'll comment on you sig since you think you know brakes. Why do you need 06 brackets?
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
