Aftermarket Strut Tower Braces
Old Oct 1, 2015 | 05:09 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Originally Posted by Depravity
I'm going to get a Cusco bar for my HR to dress up the bay a little more, it won't scratch up my intakes, and it looks a hell of a lot easier to install and remove than the OEM strut bar.
I thought most aftermarket bars have clearance issues on the hr...
Old Oct 1, 2015 | 05:15 PM
Depravity's Avatar
Depravity
I know Cusco, Tanabe, ARC, there's actually quite a lot that fit just fine. Look in this thread for some ideas
Old Oct 1, 2015 | 05:20 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Originally Posted by guitman32
The most important variable in tower bar efficacy on our platform is maintaining a linear load path between each mounting point...I think bars like the APS bars sacrifice this in the name of necessity, though im sure still effective to a lesser degree.
Torsional rigidity is less important but may contribute to overall stiffness of the bar. Bars triangulated into the firewall like on the 370 and new mustang are even better.
Those front lower bars that tie into the plastic part of the core support are only good for adding mass where it isnt wanted and therefore a waste of money, imo.
Per the FSM on OEM bar adjustment:
"INSTALLATION
1. Install tower bar and tighten at the specified torque.
NOTE:
If it is hard to install tower bar, install it turning center bolt.
2. Tighten center bolt to the direction in the figure on 660° (Or turn
bolt 1.7 times) to place the black mark of center bolt above.
NOTE:
The space between tower bar and engine collector should be
between 10.0 mm (0.394 in) and 17.0 mm (0.669 in).
3. Tighten both nut of the right and left side of center bolt."
Great info guitman32! Thanks, that clears up a lot.
Interesting your comment highlighted in the quote above.... Volvo offered their "R-Sport" strut bracing that tied into the firewall for the 200 series Volvo. They resembled copper pipes mashed down on each end and drilled for mounting.
And, if you ever look under the hood of a 240 (zzzzzzzzz......), you'd see that the holes for mounting the R-Sport bars existed on ALL production 240s.
Oh, and by the way, this was back in about 1974.
Mic
PS I might be mistaken but these were available for the earlier 140 series as well I THINK. Either way.... nothing new about strut tower triangulation.
Old Oct 1, 2015 | 05:36 PM
guitman32's Avatar
guitman32
^1 absolutely, good point on this tech being nothing new, lol.
And to take it a step further on any strut style platform, like the 240, im sure benefits of a triangulated bar are amplified due to the added forces concentrated in that area.
I forgot to mention if youve ever actually had someone stomp on the brakes while looking at the brake master and observed the movement...Im actually a believer in tower bars with an integrated MC brace.
Old Oct 1, 2015 | 06:22 PM
MicVelo's Avatar
Definitely! I think early in this thread, there was some discussion of the MC brace. I was intrigued by that. Old track trick in my S30 and roadster days, bracing up the MC but to integrate that into the design of the tower brace....ingenuity!
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
