Installed SPC Toe bolts in wrong place
Old Sep 3, 2015 | 04:34 AM
NecktieNinja's Avatar
NecktieNinja
Default Installed SPC Toe bolts in wrong place
Hey guys, in my previous thread, I said that the CSR was acting weird, and I think I found out why. I was online making sure I installed everything right, and it looks like I installed my spc toe bolts in the wrong location. I put it in the camber arm location.... As in I dremeled out the camber arm holes.I will be putting my OEM camber bolts back there, and dremeling out the correct location. Will anything be bad if I put my OEM camber arms back? Will the dremeled out room be a problem? Thanks guys, I watched a YouTube video on this and followed it, and I guess they did the wrong thing too...
Old Sep 3, 2015 | 04:47 AM
travlee's Avatar
travlee
Master
get lock out washers if you have aftermarket camber arms
http://350zhatchshocksandmore.com/Lockout%20Washers.htm
Old Sep 3, 2015 | 04:54 AM
NecktieNinja
Thanks for the quick reply travlee! So if I put these on, where I messed up, i should be fine?
Old Sep 3, 2015 | 05:02 AM
travlee's Avatar
travlee
Master
should be. see in red circles in the pic? that is where the eccentric bolts press to make the adjustment. by putting the lockouts there, they cant move, so the elongated holes SHOULDNT be a factor. this also makes the alignment place use the aftermarket arms to adjust camber
Old Sep 3, 2015 | 05:54 AM
NecktieNinja
Alright thanks!
Obadabot
Jun 18, 2023 11:31 PM
