Hierarchy of suspension components
Old Dec 25, 2015 | 08:12 PM
Bak3rme's Avatar
Bak3rme
Default Hierarchy of suspension components
I currently have BC type BR coilovers and I am going to have them re-valved this winter, so essentially new coilovers on my part.
if you were to do suspension upgrades only what order would it be in most important to least?
does this sound good? what would you remove from my list or add?
F/R sways
upgraded sway end links
upgraded UCA/LCA poly bushings
4 point brace
top strut tower brace
rear lower tie brace
Old Dec 25, 2015 | 08:26 PM
terrasmak's Avatar
Well you didn't mention the need. Are you racing the car on Hoosier A7 or driving it to Walmart 2x a week. Are we talking about a car that has 60k miles or fresh off the dealer floor.
1. Sway bars
2. End links so you can corner balance with your coilovers
3. Bushings
2 and 3 are wear items, and can easily move position if they need to we replaced.
The other stuff mentioned is useless junk.
Old Dec 25, 2015 | 08:29 PM
Bak3rme's Avatar
Bak3rme
1. Sway bars
3. Bushings
whoops! 2003 Z 124k miles looking at mountain runs and lots of spirity drivin!
Old Dec 25, 2015 | 10:35 PM
terrasmak's Avatar
1. Bushings ( front LCA and compression arm ).
2. Sway bars
3. Diff bushings if not replaced yet and subframe bushings if you can swing them
4. Endlinks , your stock ones are close to being worn out.
Old Dec 26, 2015 | 07:07 AM
Bak3rme's Avatar
Bak3rme
2. Sway bars
Thanks for info. Any recommendations on end links? OEM replacements are soo much cheaper than aftermarket.
also without a lift..how long do you it will take to drop the subframe and get those bushings out?
Old Dec 26, 2015 | 07:17 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
1. Sway bars
3. Bushings
^^^ Definitely this.
However, I would add that after EACH step, performance alignment.
Which means adjustable UCAs in front and camber arms/toe bolts (depending on need) in the rear....at least.
terrasmak's Avatar
Powergrid and SPL would be 2 main choices. If your lot going to corner balance, really there no need.
I don't have a lift, done a few sub frames. Taken about 4 hours each time
Old Dec 26, 2015 | 07:54 AM
CJs_Z33's Avatar
CJs_Z33
Did mine not to long ago. I went with whiteline bushings (lower control arm and compression arm). But for track, id use spl solid bushings. Also did lower ball joint and tie rod ends. Wasnt hard at all.
Old Dec 26, 2015 | 08:13 AM
jdmfetish's Avatar
jdmfetish
if you do the hotchkis sway bars, and wind up after use , moving to the stiffest settings , you will break OEM sway bar end links
at least I did , i broke at least 1/2 dozen , and i just daily my car , its not tracked
so i paired the hotchkis with the spl end links f & r , and have not broken any more
Old Dec 26, 2015 | 08:19 AM
Bak3rme's Avatar
Bak3rme
@JCs_Z33 Nice garage man!!!
what ball joints did you end up going with? I see you have a 2004 so did you go with the duralast ball joints from advance auto? where do the lower ball joints sit? is it on the LCA?
Old Dec 26, 2015 | 08:21 AM
Bak3rme's Avatar
Bak3rme
thanks for the heads up man! where did u get urs from?
Old Dec 26, 2015 | 08:24 AM
CJs_Z33's Avatar
CJs_Z33
Brand is SPD. Got them from conceptzperformance.com. And they sit on the knuckle.
Old Dec 26, 2015 | 08:46 AM
jdmfetish's Avatar
jdmfetish
my build thread
https://my350z.com/forum/media-share...ures-lots.html
I bought all my SPL merchandise from Kyle at Import Parts Pro
He is an approved vendor on this site
Old Dec 26, 2015 | 10:34 AM
terrasmak's Avatar
Have yet to see a need to run the stiffer settings on Hotchkiss bars. Maybe I'll need it once I go to full slicks
Old Dec 26, 2015 | 12:13 PM
jdmfetish's Avatar
jdmfetish
for me its preference , i have tried all the settings , and i prefer the least roll into the corners
I can certainly feel the difference as i move the end links from softest to stiffest
have you tried the stiffest settings to see what you prefer ?
Old Dec 26, 2015 | 12:59 PM
terrasmak's Avatar
I went off lap times, sure it feels better set stiff, feels like you think a race car would feel. Once you start pushing at 9/10 to 10/10 , that is where a properly adjusted bar is faster.
Old Dec 26, 2015 | 02:22 PM
jdmfetish's Avatar
jdmfetish
i agree that you are racing , so you do what yields best results
but for me street driving i am just doing what feels the best
thanks Terra
Old Dec 26, 2015 | 03:02 PM
terrasmak's Avatar
thanks Terra
I would rather have a system that is controllable at the limit if/when I get into an emergency situation. Beyond stupid stiff swaybars do not provide that at all.
Old Dec 26, 2015 | 03:34 PM
jdmfetish's Avatar
jdmfetish
hey your most certainly entitled , i can respect your choice
rynev33
Aug 9, 2020 08:40 AM
Turnstien
Apr 8, 2016 06:04 AM
DEMoLITIoN
Suspension
Feb 16, 2016 06:49 AM
CrazyKurdii
Jan 1, 2016 06:39 PM
jdm0830
Jan 1, 2016 09:41 AM
