Linear spring options + what drop?
Old Feb 23, 2016 | 05:27 PM
travlee's Avatar
travlee
Master
The extenders will fit through the larger hoke without any changes, and lay flat enough to get the cover back on
Old Feb 24, 2016 | 03:18 PM
rich2342's Avatar
rich2342
So, Since I am replacing the BC coilovers which are said to be undampened.
My question is if I could reuse the BC spring on the D Specs? Does that seem feasible or would there be fitament issues and/or just a bad pairing if they fit?
BC springs are rated at 560Front/450 Rear. Anyone know?
Old Feb 24, 2016 | 04:02 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
99% certain you cannot use the springs, Rich. BC's are coilovers and usually have smaller diameter windings and possibly different extended length. Apples, oranges.
You asked previously about the Swift Spec-Rs... and while I've never run them, they are HIGHLY regarded. Give them a shot and report back on this combination. It seems like it could be a really good one.
As I've said before, while springs are a KEY part of the suspension, for the manufacturers building them, this is probably the easiest thing to engineer/build. Oversimplification, yes, but once you know what you want (spring rate, diameter & length) and have a good supplier with decent spring steel, it's not rocket science for them to build.
Oh and wait a minute... BC's are "undampened"????? No...... NOT true. No such thing as an undampened coilover. That shock in there is put there for just that purpose. Maybe doesn't do a GOOD job of dampening but seriously, if your springs weren't damped, you'd KNOW it.... or your broke teeth would be a good indicator.
Old Feb 24, 2016 | 04:26 PM
rich2342's Avatar
rich2342
Yep, I figured as such looking at the pictures and how I remember them. Just trying to save a few bucks as I have to order more parts and then the labor to install all of it, BLAH...
The Swifts do seem to review nicely. So that is likely what I will pair with them, unless I come across something else 11th hour.
Funny, but I kind of enjoy a firmer ride (yes I just said that, ha ha) But I did bottom out a few times with Road irregularities and that was not pleasant.
Old Feb 25, 2016 | 04:28 PM
rich2342's Avatar
rich2342
Ok, So they are legit. Very quick shipping.
The Vendor must've been confused, as there certainly not are any rear extensions for adjustment . I will either purchase separately or just use the hex tool. Just need to grab some springs and A-arms and bushings. Then line up the install.
JM Auto Racing
Suspension
378
Dec 1, 2019 07:22 AM
openupitsdave
Feb 24, 2016 05:29 PM
Zee Dirty Tree
Feb 15, 2016 11:02 AM
VenomGT9
Feb 5, 2016 04:50 PM
350zaddict
Jan 29, 2016 03:21 AM
