rear camber kit and upper control arms
Old Oct 24, 2016 | 06:06 PM
Tomek350Z's Avatar
Tomek350Z
Can someone explain the so called spacers at the bottom left and right?
Old Oct 24, 2016 | 08:18 PM
terrasmak's Avatar
Those are a pain to work with, the new d ensign not shown is much better
Old Oct 25, 2016 | 01:15 PM
deeliciousqueen's Avatar
deeliciousqueen
Just sharing my experience with Kinetix FUCA. Been to two reputable shops and they both dislike it. It is a blind adjustment basically you guess where the ball joints adjust and then if you don't get the specs you want you'll have to remove the wheel again adjust the ball joint and do the same thing over and over until you reach your desired spec.
I have nothing against Kinetix FUCA but just sharing my 0.2
Old Oct 25, 2016 | 01:45 PM
Tomek350Z's Avatar
Tomek350Z
I figure, but I cant even imagine what they are for, the camber is obviously adjusted with the large nut/balljoint moving fore and aft. But what is the purpose behind these so called spacers? Caster?
thanks for the input, I have heard this from others as well
Old Oct 25, 2016 | 01:57 PM
Tomek350Z's Avatar
Tomek350Z
https://www.z1motorsports.com/suspen...35-p-9583.html
looks like its for more camber adjustability
YardieXplorer
Mid-Atlantic
Oct 13, 2013 07:19 PM
zred
May 16, 2009 11:57 AM
gsazabi
Aug 17, 2006 02:37 PM
SJTrackZ
Apr 27, 2005 11:53 AM
