Replace the control arm when I replace my ball joints?
Old Nov 29, 2019 | 11:52 AM
OrphenZidane's Avatar
OrphenZidane
Default Replace the control arm when I replace my ball joints?
I have an 06 Touring. I was thinking of getting a shop to replace my lower front ball joints since I am lazy. The shop I called said it would be $800 because they have to replace the control arms in order to replace the ball joints, as well as giving it an alignment. I think they are full of bs. Are they correct? Can't they just replace the ball joints without having to replace the control arm?
Old Nov 29, 2019 | 12:39 PM
iideadeyeii's Avatar
iideadeyeii
You can but it's like $25 for a ball joint and $50 for the rearward lower control arm with the ball joint already in it
Old Nov 29, 2019 | 11:52 PM
DarkZ03's Avatar
DarkZ03
You got the suspension mixed up, the ball joint is pressed into the spindle/knuckle. The control arm has 2 bushings and a hole for the ball joint stud.
Anyway, is that price labor only or everything?
if it were me, you are going to have to align for everything you do, so might as well do ball joints, tie rods, control arms and compression rods all at the same time, the labor difference should be minimal and the the car would be set for a while.
Old Dec 3, 2019 | 08:20 AM
iideadeyeii
Oh, I was thinking of the ball join on the rear arms. Either way it can be pressed out/in
Old Dec 4, 2019 | 11:04 AM
Cracka350's Avatar
Cracka350
I've done ball joints on the lower control arms 3 times. It's a god awful job pressing out old and pressing in new ones. I say buy the control arm pre pressed. It'll save you hours.
Old Dec 11, 2019 | 02:45 PM
Spike100's Avatar
Spike100
I replaced the control arms for the very reason you mention.
Chuck Odum
Oct 31, 2019 08:26 AM
ovalnegri
Jan 10, 2018 04:42 AM
GarniZ33
Jul 7, 2015 07:31 AM
AAB350z
Jul 22, 2013 11:26 AM
robmaz26
Oct 22, 2011 05:28 AM
