Dual caliper setup
Old Feb 4, 2020 | 01:51 PM
350zjackg's Avatar
350zjackg
Default Dual caliper setup
Hello all does any one know what cheap Calipers will fit my brembo disc set up as looking to go dual caliper set up thanks all help is appreciated
Old Feb 4, 2020 | 02:35 PM
travlee's Avatar
travlee
Master
If this was already covered on here .........(sarcasm)
Old Feb 5, 2020 | 07:01 AM
jhc's Avatar
jhc
General & Tech Moderator
Actually no one I've ever heard of here runs that setup. I've been here 7+ years. Gl!
Old Feb 5, 2020 | 07:08 AM
iideadeyeii's Avatar
iideadeyeii
Run an extra factory caliper with a custom bracket. IDK why it would be needed. My factory non-brembo's are incredible good on my Z or unless you want to install a hydraulic e-brake or something?
Old Feb 5, 2020 | 07:24 AM
813_350Z's Avatar
813_350Z
https://my350z.com/forum/brakes-and-...rs-ebrake.html
Start at post 6.
Old Feb 5, 2020 | 12:59 PM
350zjackg's Avatar
350zjackg
Originally Posted by 813_350Z
thank you everyone for replying here’s another question do the stock brake calipers (non brembo)fit the brembo discs if not what cheap calipers do?
Old Feb 6, 2020 | 05:31 AM
iideadeyeii
What you need to do is research car rotor sizes. Find one with same size/thickness rotors as what you have on the car and then those calipers will fit.
Old Feb 8, 2020 | 05:04 PM
bboypuertoroc's Avatar
bboypuertoroc
There's over an inch size difference between standard Z rotors and factory Brembo rotors. Why is this even a question?
Old Feb 10, 2020 | 09:24 PM
terrasmak's Avatar
Almost better off converting to regular rear brakes as you can get spare from the junkyard for pennies
rubabealf
Dec 22, 2020 08:04 AM
AjPietig
May 25, 2015 11:47 AM
Zlut
Drift
May 8, 2015 01:23 AM
wduvall
Feb 7, 2007 08:38 AM
