Brake failure
Old Mar 5, 2022 | 03:52 PM
Rguido17's Avatar
Rguido17
Default Brake failure
Have owned an 05 350z for a bout half a year now and haven't had any problems with it but lately had the car shut off on me about 3 times in 2 months at a stop and just last week I was driving under a bridge and going down I suddenly felt like a car had hit me from behind checked but there was no car near me and suddenly brakes stopped working and battery light, brake light, engine light came on turned the car off then back on and it all went back to normal ,wanted to know what could have caused this luckily I was driving slow and the car stopped at the bottom.
Old Mar 5, 2022 | 03:55 PM
Ponyryd's Avatar
Ponyryd
Stick or auto? Any modifications?
Old Mar 5, 2022 | 04:00 PM
Rguido17's Avatar
Rguido17
Automatic and not modifications all stock
Old Mar 5, 2022 | 06:35 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Have you tried pulling codes? The ABS section will provide separate codes and will definitely hold in memory anything that led to total brake failure.
Old Mar 6, 2022 | 07:33 AM
jhc's Avatar
jhc
General & Tech Moderator
Emergency braking is not a feature on an '05 Z33. As stated above, you should get any codes read.
Old Mar 6, 2022 | 07:49 AM
Rguido17's Avatar
Rguido17
Thank you will check haven't driven it since then ,but will see if it has any codes
Old Mar 6, 2022 | 09:36 AM
dkmura's Avatar
dkmura
Re-read your original post, and wonder if your Z actually shut down completely when going down under that bridge. If the engine stopped, you won't have any hydraulic assist for your brakes and the car will feel very heavy without power steering. You should still check on any codes held in memory and correct them before starting to assume it's a defective brake system.
billybronco1
350Z Roadster
16
Oct 12, 2016 08:41 AM
VQpoweredZ
May 23, 2008 05:55 PM
MrWatchDawg
Jan 21, 2008 09:13 AM
silverspeedz
Nov 25, 2005 09:36 AM
samors
Feb 13, 2004 12:22 PM
