Brembo upgrade hard lines
I think I'm making myself crazy here! I have a '03 with standard brakes and bought a new set of Brembo calipers, rotors and pads. I bought OEM rubber lines from Oreilly and now I need the hard lines! and now apparently the RR or LR is discontinued for some reason!!! I should of just bought the Z1 SS kit and moved on but I wanted to make things complicated and do a OEM setup...
Does anyone have a set of hard lines they would like to sell?? I'm debating whether to buy some SS hard line and make them myself, but I don't know if it's 3/16 or some metric tubing. I can flare the ends and bend it as needed but not 100% sure on the tube size. Any knowledge or input would be much appreciated.
- side note, the car is new to me and I haven't even removed a wheel so I don't know what's back there yet, the standard brakes don't use the hard lines correct?
thank for reading!
thank for reading!
Do you mean the actual hard lines that run from the ABS to the wheel well? Or the lines that run from that junction to the calipers? If it's the latter, you can get good upgraded braided lines from a dozen reputable manufacturers (HEL, GKTech, Chase Bays, ISR etc..).
eat rice z33
Dec 5, 2006 11:07 PM
spacemn_spiff
Jan 15, 2006 08:16 PM
