Z32 (300ZX) Brakes on a 350Z?
Old May 22, 2012 | 10:59 PM
  #161
R350Zz33's Avatar
R350Zz33
if you have a 03-05 z grab a set of 06 and up brakes even the non brembos are an upgrade
Old May 23, 2012 | 02:25 AM
  #162
SirSpeedyZ's Avatar
SirSpeedyZ
Originally Posted by SuperBlack350z
downgrade
Old May 23, 2012 | 07:05 AM
  #163
terrasmak's Avatar
06 and newer non Brembo brakes will be better than the 300Z brakes. Not sure about the 03 to 05 non-Brembo setup.
Old May 23, 2012 | 07:24 AM
  #164
angelo350z's Avatar
angelo350z
downgrade
+100000000
Besides, those calipers are meant to be used on tiny 11" rotors so you'll get a good amount of unswept area on your OEM rotors.
Old May 23, 2012 | 07:54 AM
  #165
lgear080's Avatar
lgear080
Let's just say using washers to adapt a brake caliper is a terrible ****ing idea.
Old May 23, 2012 | 08:22 AM
  #166
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Like the others have said, it's a downgrade for several reasons. Even if performance were better with the 300ZX brakes, I'd stick with the Z33 brakes unless performance difference was huge.
Old May 23, 2012 | 08:26 AM
  #167
bmccann101's Avatar
bmccann101
I use the calipers off a 1981 Volvo 240DL on my ride.. so to hell w yal.
Old May 23, 2012 | 08:51 AM
  #168
ksmoore's Avatar
ksmoore
Its not necessarily a downgrade from base non brembo calipers...
And whn I stated washers, I meant at least three to four medium thickness washers total on both calipers.
To each his own, but they do work
Old May 23, 2012 | 10:16 AM
  #169
lgear080's Avatar
lgear080
When you rip your front knuckles, hardware and calipers apart
Please don't say I didn't warn you.
Old May 23, 2012 | 10:52 AM
  #170
ksmoore's Avatar
ksmoore
I driven 6k miles on that set up with no issues, then sold the car....
I still the car rolling around with the brake setup a year later
Old May 23, 2012 | 11:15 AM
  #171
ronn1's Avatar
ronn1
He definitely has SINGLE piston (pre 06) fronts....so this is prolly the CHEAPEST solution and a good choice as well. If I were to go through the trouble of doing this, I would do the Brembos and call it a day.
Old May 23, 2012 | 11:36 AM
  #172
Waiz's Avatar
Waiz
There are several threads on this topic so I have merged them together for easier reference
JjL
East Canada
Jun 12, 2019 03:04 AM
Vigman
Nov 17, 2015 04:34 AM
jlc280z
Sep 24, 2015 08:43 AM
hardkicks
Sep 20, 2015 12:28 PM
