brake pads install
Old Mar 15, 2004 | 03:06 PM
jim911's Avatar
jim911
Default brake pads install
I did a rear brake pad switch on the rear this weekend. It was pretty straight forward. I'm waiting for the front Brembo pads. Has anyone changed those out? Pictures, difficulty?
Old Mar 15, 2004 | 04:08 PM
John's Avatar
John
Jim, the front Brembo pads are just as easy as the rears. Just pull out the cotter pins, then pull out the cross-member pins with the leaf spring. Then pull out the brake pads, use one brake pad as a lever to compress the piston so that you can slide in your new brake pads. I can do all 4 in about 30 minutes, and that's with drinking beer, getting distracted, and without air tools.
Old Mar 15, 2004 | 05:00 PM
jim911's Avatar
jim911
That sounds like I work! Thanks
Old Mar 18, 2004 | 03:16 PM
isalvus's Avatar
isalvus
do the brembos kick alot of brake dust? and can you use on other
than track models and is stopping power increased? and finally what do they cost? thanks for the info!
Old Mar 19, 2004 | 06:27 AM
John's Avatar
John
The OEM pads on the Brembos are made by Ferodo, and yes, they dust a decent amount.
The rest of your post is unintelligible, so rephase and ask again.
Old Mar 19, 2004 | 11:23 PM
D'oh's Avatar
D'oh
I think he's asking if you can use the Brembo pads on non-brembo brakes, and the answer is NO.
Don't know cost of Brembo pads, but non-brembo are about $50 a pair from Nissan and probably less aftermarket.
-D'oh!
Old Mar 20, 2004 | 06:11 AM
John's Avatar
John
I'm glad you could translate for him D'oh.
The OEM Brembo pads are pretty much the same price...
samansharif
Sep 25, 2015 12:31 PM
