TEIN Flex install
Old Apr 5, 2004 | 09:35 PM
thawk408's Avatar
thawk408
Default TEIN Flex install
What is the best amount to lower the car apon install with 245/35/19 and 275/35/19?
Thanks
Old Apr 5, 2004 | 10:27 PM
failsafe's Avatar
failsafe
....for your health
Whatever you like- If you are going to be tracking the car regularly you should get it cornerweighted.
Old Apr 5, 2004 | 11:07 PM
thawk408's Avatar
thawk408
Not going to track it that much. Mainly for street driving and good looks. What would be the best setting without me haveing to get a camber kit or worrying about uneven treadwear?
Old Apr 6, 2004 | 10:23 AM
thawk408's Avatar
thawk408
I saw on some stores website (cant remember which one) recommended .9 inch/F and .8 inch/R. Does that sound good?
Old Apr 7, 2004 | 08:18 AM
thawk408's Avatar
thawk408
Does anyone have an answer for me?
Old Apr 7, 2004 | 08:30 AM
thawk408's Avatar
thawk408
Well, if I just go ahead with the drop that I listed above, how much will this set off my camber with me having 245/35/19 and 275/35/19? What will I have to get to correct this? Will I rub any?
Old Apr 7, 2004 | 01:57 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
only way to tell how much camber is affected is by putting it on the rack - I suspect that even with a 1 inch drop you'll be way off camber wise.
As for rubbing, depends on your wheels, tires etc...trial and error I suppose
Old Apr 8, 2004 | 10:04 AM
thawk408's Avatar
thawk408
I am going to get the Volk Challenge in the correct offset and width to fit 245/35/19 and 275/35/19. What about rubbing issues wiht those rims and tires and an inch drop?
Old Apr 9, 2004 | 12:36 PM
bboyhook's Avatar
bboyhook
I would go with .8 inch front and .9 inch back. You will definitly need a camber kit. As far as rubbing goes there wont be any going on. Way to go big swoll
Old Apr 21, 2004 | 08:56 PM
thawk408's Avatar
thawk408
If i lowered it 1.5 inch, would i do that in the front and back? Or would it be better to have the back alittle higher then the front? What would be the best performance heights?
nanotech
Oct 2, 2015 05:02 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
