Hawk HPS brake Pads?????
Old Apr 14, 2004 | 11:03 AM
rclab1's Avatar
rclab1
Default Hawk HPS brake Pads?????
am planning on putting these Hawk HPS brake pads
on my '04 roadster, it has 3800 miles on it,,,,
if i replace only the Front brakes, will there be
a slightly different feel on my brake pedal
b/c the Rear brake pads are slightly more worn in
compared to the ones going to be put up front (Hawk HPS)
or will it AutoMatically self adjust?
please let me know.....
is there any break in procedures also for
the new front brake pads?????
thanks
Old Apr 14, 2004 | 11:35 AM
jpc350z's Avatar
jpc350z
Default Re: Hawk HPS brake Pads?????
thanks
Installed the HAWK HPS this weekend with 3200 miles on old brakes with no noticeable effect on braking. The box has directions on seating the new pads..
Old Apr 14, 2004 | 01:35 PM
speedform's Avatar
speedform
Did you buy the Hawk's yet? I heard their hard on the rotors compared to a Carbotech or Pagid pad.
You should do a few 60mph to 0mph hard stops then a couple 80mph to 0mph to help bed in the pads.
Old Apr 14, 2004 | 02:27 PM
Bertg's Avatar
Bertg
This is from Raceshopper.com:
Hawk Brake Bedding-in Procedure
Step 1:
Make 6-10 slow-downs from approximately 30-35 mph to 5 mph. applying moderate pressure. Do not come to a complete stop.
Step 2:
Make an additional 2 to 3 harder stops from approximately 40-45 mph. to zero.
Step 3:
DO NOT DRAG THE BRAKES! (after stopping - do not leave your foot on the brake pedal)
Step 4:
Allow 15 mintues or more for the brake system to cool down.
Step 5:
Your new Hawk pads are ready for use.
Old Apr 14, 2004 | 09:18 PM
ZISBAK's Avatar
ZISBAK
I had put those on when the stock pad start to run out around 10k miles, they brake really nice, but for some reason, my still squeak all the time at low speed. I've bedd them and everything, it will go away, then it will come back again. I've just reach close to 19k miles now, and the long squeak to stop has came back big time!! Pretty much every single stop now? Has anyone experience that? Does those pad wear out fast too? and I don't think I drive that hard? Anybody?
oh, I had cut the rotor around 12k miles, so the rotor should be fine.
Old Apr 15, 2004 | 07:46 AM
rclab1's Avatar
rclab1
Default did you replace the fronts only or both the front and Rears?
anyone?
Old Apr 15, 2004 | 07:52 AM
jpc350z's Avatar
jpc350z
Default Re: did you replace the fronts only or both the front and Rears?
anyone?
Front only for me. Had only 3k miles on the pads..
Old Apr 15, 2004 | 08:19 AM
bixby's Avatar
bixby
Man, I just got mine & haven't installed yet. I hope they don't squeak.
Old Apr 15, 2004 | 08:32 AM
jpc350z's Avatar
jpc350z
Don't know if it's necessary but I put a brake lubricant on the pads..
Old Apr 16, 2004 | 06:55 AM
FCallender's Avatar
FCallender
If you replace the fronts only make sure you have a pair of rears handy. The rears wear faster due to the bias and their smaller size. I replaced both with a harder front pad and noticed less understeer due to the increased grip from the fronts.
Axxis ultimates front, Porterfields rear. Neither are true track pads but are a good compromise for street and occasionl track.
Squeeking is more a function of pad pressure, especially for high perf pads. Try getting on them hard and off fast.
Old Apr 30, 2004 | 10:35 AM
rclab1's Avatar
rclab1
Thumbs up just got the Hawk HPS
Just got my Hawk HPS front brake pads put on and
embedded them too.....
I was concern about the OEM pads that gave
too much dust.....
i changed over to the Hawk HPS pads and
WOW!
what a complete difference in Dust....
sooooo Much Less dust now....
am very happy
and its not squeeking like some are saying.....
thanks a lot for everyones' input
Old Apr 30, 2004 | 10:42 AM
bixby's Avatar
bixby
I know this is a little late since you've already installed but, I installed mine on the front only with about 8k miles on the car. I applied the "no squeak" gell to the back of the pads & bedded them per the instructions. I have absolutely no squeak and love the fact that the dust issue is resolved. all that dust drove me nuts! I'll install on the rear when I need new pads.
Now that I know they work I think I'll put them on my other cars too.
Old May 1, 2004 | 05:46 PM
neur0sis's Avatar
neur0sis
Well, I have had the Hawk HPS installed for a few months now, and they just started squeeking in the front... (Front Right, specifically)
I have tried doing a couple hard stops, but to no avail.
I am going to take the pads off this weekend, and rough them up a little with some 100 grit sandpaper, re-apply some anti-squeel on the back of the pads, and re-install. I might take a scotchbrite pad and some soapy water to the rotor as well, to make sure there is nothing stuck on the rotor surface as well...
samansharif
Sep 25, 2015 12:31 PM
