drop without camber adjusters.. how long did tires last? (eibach drop guys)
Old Jul 22, 2004 | 11:27 AM
RazNips's Avatar
RazNips
Default drop without camber adjusters.. how long did tires last? (eibach drop guys)
I am getting tein basics (i know the topic says eibach, but thats just because that is the same drop i will be setting my basics to). For those of u running as close to factory spec as possible without camber adjusters, how long are ur tires lasting in between changes? How long WOULD they be lasting... im trying to figure out mathematically if it will be worth it to me to spend what a new set of tires would cost for camber arms. I am just goin back to good ole algebra I. There are two different linear equations here and i want to see at what # of miles they cross and are the same price.... help me out
btw my setup with be volk gt-c 245-35-19/275-
35-19 8.5 front and 9.5 rear with tein basics at about a 1.3 inch drop all around.
and how is driveablility changed with negative camber? I have heard that it is better for traction and turning.. is this tru? it would make since i guess logically
Old Jul 22, 2004 | 05:30 PM
mgtibbetts's Avatar
mgtibbetts
Are you serious? Here's an equation for you: rationalization + 350z = No Fun.
Old Jul 22, 2004 | 06:06 PM
KShep's Avatar
KShep
You can go 0.80 inches lower and stay close to spec camber. I am one inch lower and have been told I can expect a 10% reduction in treadwear. Sorry, those are the only numbers I have.
Old Jul 23, 2004 | 07:29 AM
dwnshift's Avatar
dwnshift
Its not just about tread wear........its also about safety. Too much neg camber will effect braking....ecsp in wet conditions.
Old Jul 24, 2004 | 07:34 PM
basam350z's Avatar
basam350z
My cars camber is 2.3 or both backs. 2.1 is max spec, I have eibach. The main thing to consider is toe, not camber.
Old Jul 25, 2004 | 05:29 AM
2003z's Avatar
2003z
I just replaced my tires with about 15000 miles on them. I had the car aligned when new, but never got around to doing it after lowering. the rear tires had no abnormal wear at all, the fronts just a very slight feathering, but thats because the alignment shop was unable to get my toe into spec.
Old Jul 25, 2004 | 05:31 AM
2003z's Avatar
2003z
Now, our G35c that we had is another story. I lowered it, then got it aligned 3000 miles later and the insides of the rears were already feathered quite a bit. The toe was out 7 degrees! they couldn't get that into spec either, but played with the camber and were able to make up for it.
Old Jul 25, 2004 | 09:55 AM
G352NV's Avatar
G352NV
after 8000 miles with the drop my front are DONE! I guess Im going to have to sack up and buy a camber kit!
emooheo
Oct 14, 2015 08:58 AM
seagrasser
Oct 11, 2015 03:27 PM
Mw870
Sep 10, 2015 07:50 PM
