Please HELP!!! Big Brake Kit problems?!
Old Oct 12, 2004 | 01:55 PM
Zenvy's Avatar
Zenvy
Default Please HELP!!! Big Brake Kit problems?!
so I got my stoptechs about a year and a half ago and all is fine. then recently, my brake rotor or something in the front right tire well is emitting a loud humming noise @ 50 mph or so...i apply the brakes and the noise goes away.
I thought it was a bent front right wheel...so i got replacement wheels and tires...no problems with tire/wheel sizing as i got them from tire rack.
Then the noise comes back again!!
I bedded the pads as they recommended...i don't know what could be causing this. it definitely sounds like a metallic dull hum...no shrieking.
PLEASE...SOMEONE MUST KNOW SOMETHING ABOUT THIS!!
Old Oct 13, 2004 | 06:06 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
something loose?
did you contact stop tech?
Old Oct 13, 2004 | 06:26 PM
PhoenixINX's Avatar
PhoenixINX
Sounds like they are defective... I strongly recommend you take them off and send them to me.
I'll be happy to replace with my OEM brembos.
Old Oct 13, 2004 | 07:04 PM
Zenvy's Avatar
Zenvy
Originally posted by Jason@Performance
something loose?
tried to contact Stop Tech but no one answers their phone or returns my messages...
'...mailbox 105...' is all i hear. i hope nothing is loose...i'm taking the car into the dealership to find out what could be wrong and hopefully fix it!
Old Oct 13, 2004 | 07:23 PM
Jason@Performance
Performance Nissan
what time are you calling?
PM me your phone number / name / where you bought them from and I will have them call you
Old Oct 14, 2004 | 11:00 AM
King Tut's Avatar
King Tut
Have YOU taken off the wheel and visually inspected the brakes? See if there are any grooves on the rotor or anywhere you can see the kind of wear that could cause a noise.
Old Oct 14, 2004 | 03:09 PM
Jason@Performance
Performance Nissan
should be getting a call shortly...
Old Oct 14, 2004 | 03:49 PM
J Ritt's Avatar
J Ritt
Jason gave me a heads up on this. I'm not sure why you weren't able to reach someone. If you are in a crisis situation, you can always speak with someone in another department. We are definitely experiencing an extraordinarily high volume of calls right now leading up to SEMA, and we're doing our best to get back to everyone ASAP. Thanks.
Jeff
Old Oct 14, 2004 | 05:29 PM
Chebosto's Avatar
Chebosto
speaking of which.. i need to talk to Matt again, Jeff- same topic as last time..
thanks
--Cheston
Old Oct 14, 2004 | 07:44 PM
Zenvy's Avatar
Zenvy
Just spoke with Matt from Stop Tech...very nice person. Gave me a lot of potential solutions to the noise.
One thing i did notice from recently inspecting my brakes tonight is that there was brake dust/material within my cross drilled holes (~12 holes or so)...never saw that before...and it only was on the affected wheel...the rotors are fine..no evidence of warping
anyway,
I'm gonna re-bed the pads as i have quite a bit of pad left >1/4" as soon as the roads become dry.
Old Jan 16, 2005 | 04:43 PM
JDMautoworks's Avatar
JDMautoworks
sounds like its the pads....had similar problem then got new pads and sound went away.......
Old Jan 22, 2005 | 08:53 AM
Zenvy's Avatar
Zenvy
what pads did you use?
Old Jan 23, 2005 | 10:34 AM
GZire's Avatar
GZire
Sounds like the pads are continuously rubbing on the rotors. Potentially pads or a warped rotor.
TDPrank
Sep 29, 2015 12:51 PM
TDPrank
Sep 28, 2015 06:29 AM
samansharif
Sep 25, 2015 12:31 PM
