Rotor Removal
Old Oct 19, 2006 | 03:03 PM
fcastano's Avatar
fcastano
Default Rotor Removal
I have an 03 Track with the brembo brake system i am trying to remove the rotors to get them resurfaced. Can anybody tell me how to remove these rotors, a friend of mine just told me to wack them with a rubber mallet but thats not working. Can anybody help?
Old Oct 19, 2006 | 06:04 PM
GaryM05's Avatar
GaryM05
Make sure that the parking brake is disengaged (on the rears, that is).
Old Oct 19, 2006 | 07:17 PM
orngez's Avatar
orngez
the rubber mallet technique is the best...strike it right in the middle and it'll work its way loose..oh and some wd-40 for 20 minutes over the studs helps out...
Old Oct 23, 2006 | 03:03 PM
nothix's Avatar
nothix
they are quite stubborn. try getting a little rougher (dont brake em!)
Old Oct 23, 2006 | 03:58 PM
Mathys's Avatar
Mathys
The front ones will come off pretty easy. The rears are really tight. It's nice to loose the parking brake bolt a little, which makes it easier to take the rear discs of. Don't forget to adjust the parking brake again though when everything is installed again.
Old Oct 23, 2006 | 05:33 PM
GReddySetGO's Avatar
GReddySetGO
I'm assuming you already removed the caliper? They should just come right off.
Old Oct 23, 2006 | 07:19 PM
SS21CA's Avatar
SS21CA
Once you remove the caliper, the rotors should come right off.
Old Oct 29, 2006 | 02:08 PM
Mathys's Avatar
Mathys
Ever tried to take the rear rotors off yourself??? Then you know it's a real PITA.... For most people anyway.
Old Jan 19, 2007 | 11:20 PM
craZ350's Avatar
craZ350
there's a threaded hole on the rotor that you can use to pop it off, simply thread a screw (make sure it's the correct size and pitch) into the hole and keep turning until the rotor pops off!
Old Jan 20, 2007 | 05:37 AM
Kolia's Avatar
Kolia
Why do you need to resurface them ?
Old Jan 20, 2007 | 05:46 AM
Scarab440's Avatar
Scarab440
i used one of these with great results.
3 jaw universal puller.
Old Jan 20, 2007 | 08:12 AM
Can you show a photo of a rotor with a hole in it? When you thread a bolt into the hole, what does the end of the bolt press against? Thanks.
Old Jan 20, 2007 | 08:17 AM
a. Spray front and back of rotor with penetrating spray. Let sit for 10 minutes.
b. Front rotor: you can turn the steering wheel to give you room to swing a mallet (big hammer). Use a 1x4 to protect the rotor.
Old Jan 20, 2007 | 07:07 PM
guitman32's Avatar
guitman32
I posted this a little while ago here @ post #5:
https://my350z.com/forum/showthread....70#post3173770
"You need to loosen the parking brake shoes. There is a little rubber plug on your rotor. Align this plug so it is at 11 or 12 o'clock. Then remove the plug. Now, with a flathead screwdriver, you need to turn the adjuster to loosen the parking brake shoes. If you do this, the rotor will come off freely just as the fronts. I see too many threads of people pounding away, when that is totally unnecessary and probably damages your parking brake system and rotors. The FSM is your friend:
Once you have replaced your rotor or completed whatever work you are doing, you need to re-adjust the parking brake. From the FSM:
Cheers"
Old Jan 21, 2007 | 05:26 AM
Kolia's Avatar
Kolia
Against the hub
Old Jan 21, 2007 | 09:35 AM
Cheers"
I printed the instructions, and put them in my how to folder. Much appreciated.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
