Buying/Leasing 350Z/370Z Purchasing Info
By '05 Now? Or Wait 1 Month?
Old Oct 8, 2007 | 02:44 PM
Master Shake's Avatar
Master Shake
Default By '05 Now? Or Wait 1 Month?
I might finally be ready to pick up my first Z! I am looking at a couple of '05's that are right around $21-$22K range.
However, some people on this forum think that the new '08's will come out within a month or so. If this happens, do you think there will be a drastic affect on the price of '05's? -- something like $2-$3K less?
I would hate to pickup an '05 this weekend only to see the overall prices drop drastically, if the '08's do in fact come out within a month or so.
What do you think?
Old Oct 8, 2007 | 08:00 PM
Originally Posted by Master Shake
some people on this forum think .
And some don't.
Old Oct 8, 2007 | 08:33 PM
SniperHunter's Avatar
SniperHunter
The car will not depreciate just because a new model comes out. Look at the impact the 2007 Z had, nada. The 2008 will be identical to the 2007 Z, so nothing will change. Get the car and start enjoying it.
Old Oct 8, 2007 | 10:01 PM
victor1's Avatar
victor1
Depends what you can afford. If you buy the 2008 make sure you can afford it. its almost 10K difference thats like $200.00 more per month! And BTW in 2 years the value of the 08 will depreciate almost 10K meaning you'll be throwing away that 10K.
Old Oct 9, 2007 | 04:38 AM
zeekle's Avatar
zeekle
the 05s have already taken the biggest hit they are going to take. I don't expect to see them drop that much over the next month just because a new model is coming.
Old Oct 9, 2007 | 12:10 PM
___DJK___'s Avatar
___DJK___
Originally Posted by davidv
And most don't.
corrected for truth
Old Oct 13, 2007 | 04:15 PM
Master Shake
Thanks for the replies! I finally went out and test drove two Z's today. One was an 05 Touring Roadster w/29K miles, and one 06 Base coupe w/15K miles. Both were 6-speed manuals.
I've read a lot about the very high clutch engage points on these cars, but man, either both clutches are just about out/done, or this will take some getting used to!
So, just to confirm, both clutches basically felt like I could simply rest my foot on the clutch pedal and shift -- pressing the pedal to the floor meant I had to let it almost completely out before it engaged. Is this normal?
Also, with the clutch pedal pressed in and the car in gear, the shifter **** seriously vibrates. It's not so bad when in neutral, and/or when the clutch pedal is not pressed in -- and not so bad when in gear and driving. Is this normal too?
Old Oct 13, 2007 | 10:19 PM
The clutch engagement point is relative. But yes, compared to many other cars, the engagement point is high.
Old Nov 22, 2007 | 08:04 PM
Phoenix
Color:
Redline
Trim Level:
Touring Roadster
MyMods:
Nismo Exhaust & Intake, Brimbo Brakes
Congratulations.
Old Nov 28, 2007 | 12:26 PM
Master Shake
Thanks davidv! Digging around through old posts???
Just as most people here have said, I am glad that I made my purchase. And I did finally get used to the clutch, after about a week.
For anyone who is on the edge of decision, just go for it! Saving a little bit of money now will not compare with the actual ownership...
As for the car: So far, I've had the 30K maintence done, an alignment and re-balance of all four tires. Shortly after, I had to pickup completely new front tires due to feathering, since they were already worn. I also had the MAF replaced (under warranty) due to low idle/stalling. Checking my alignment sheet, the front toe settings were way out of spec, so hopefully the new front tires will last this time. I guess the previous owner never had the feathering issue corrected.
Old Nov 28, 2007 | 01:59 PM
victor1's Avatar
victor1
Congrats, im a 05 Z owner aswell. I waited till it depreciated and bought it this year.
Old Nov 28, 2007 | 02:48 PM
TheGest's Avatar
TheGest
get an 07 enthu
Old Nov 28, 2007 | 03:20 PM
Just checking up on you. Its my job.
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
Tochigi_236
Sep 27, 2015 03:40 PM
