Rubber build-up....
Old Nov 3, 2005 | 11:06 AM
cessna's Avatar
cessna
Default Rubber build-up....
So after burning way too much rubber on my G, the exaust, rear skirt, and wheel wells (Cant spell) are covered in the $hit....
Any suggestions???
Thanks in advance,
Louis aka: PostWhore
Old Nov 3, 2005 | 12:05 PM
cessna's Avatar
cessna
WOW,
I cant be the onlyone with this issue at hand...Can I???
Regards,
Your Official PostWhore
Old Nov 3, 2005 | 12:09 PM
Anomaly's Avatar
Anomaly
Just so I'm certain what you're refering to...
Rubber - Tires?
Or is it the tire dressing that is applied to the sidewalls that usually gets splattered along the side of the car (esp. after going through a puddle)?
If it's just the tire dressing crap, then a simple wash/wax will remove all that since it is basically a grease at that point.
If it's tire particles, try using WD40.
Old Nov 3, 2005 | 12:20 PM
cessna's Avatar
cessna
Its the tire particles....
WD40 did not work....
Any other suggestions???
Old Nov 3, 2005 | 01:19 PM
barthelb's Avatar
barthelb
Master
Take it to a self car wash and hit it up with a pressure washer, just dont get tooo close.
Old Nov 3, 2005 | 01:53 PM
DavesZ#3's Avatar
DavesZ#3
Soak it down good with either mineral spirits, kerosene or WD40. It may have to sit on there a while to loosen/dissolve the gook.
Old Nov 3, 2005 | 02:06 PM
cessna's Avatar
cessna
Thanks guys I'll try that tonight!
Cheers
Louis
Old Nov 3, 2005 | 04:30 PM
95snoozer's Avatar
95snoozer
mine melted into the paint... i will try the kerosene... i would think that would eat my paint
416blueZ
Jun 11, 2024 10:56 AM
TrackFiddy
Sep 24, 2015 11:40 PM
416blueZ
Sep 24, 2015 02:11 PM
EnjukuRacing
Sep 18, 2015 07:57 AM
Suffolk350z
Sep 13, 2015 02:43 PM
