Wax by hand or with electric buffer?
Old Mar 21, 2006 | 07:26 AM
shortbus1981's Avatar
shortbus1981
Default Wax by hand or with electric buffer?
Im curious....what do you feel the best way to wax is? By hand or using an electric buffer like detail shops use? The buffer definitely makes the job go faster and they have microfiber pads for em, but is it better on the paint to do it by hand?
Old Mar 21, 2006 | 08:42 AM
DavesZ#3's Avatar
DavesZ#3
First off, it depends on what product you're talking about. If it's a true carnauba wax, then you will want to use a machine. Synthetics are made so you can just wipe them off with very little effort so a machine might be overkill.
I follow the school of thought that the less you rub the surface of your paint, the less chance of introducing swirls. Also, if you wash, wax and polish with consistent linear motion, any scratches you do introduce are less noticeable.
If you've got a machine spinning several hundred RPMs and a spec of dust gets under it you could easily introduce some fine scratches.
Keep in mind that detail shops make their money in volume. The quicker they do a car, the more they can make in a day. For them, a machine is a necessary evil.
Old Mar 21, 2006 | 11:15 AM
shortbus1981
Well I was thinking about trying that Meguiars NXT wax. Should I do that one by hand?
Old Mar 21, 2006 | 11:28 AM
mikead_99's Avatar
mikead_99
The best results I've gotten from NXT (on an SB Maxima, hasn't been on my Z yet) was applying by hand and then removing and polishing with buffer. Blew away the job I did by hand before then.
Old Mar 21, 2006 | 02:22 PM
shortbus1981
Hmm Ill have to give that a shot. What'd you apply it with? Microfiber?
Old Mar 21, 2006 | 02:29 PM
mikead_99's Avatar
mikead_99
Actually it was just one of those terry applicators. For application I tend to by a handful of applicators at a time, either terry or mf whichever I get my hands on. I can't say I notice a difference in the two, but I only use an applicator once and toss it. Mf to remove and buff always though, but that's just my way.
Old Mar 21, 2006 | 09:14 PM
I've tried a buffer and found that it was a pain in the butt: changing pads, cleaning and replacing pads. Then I had to do the the areas that I missed (around door handles, insignia) by hand. Time saving? Heck it took me more time.
Old Mar 22, 2006 | 02:24 PM
Nexx's Avatar
Nexx
use zaino, best shine, no machine needed, wipes off easily using a microfiber towel.
Old Mar 22, 2006 | 02:51 PM
shortbus1981
far too many steps for me to bother with Zaino. I dont have a couple hours to blow on the weekends....Im a tad busy. I want the quickest quality wax I can get and it seems NXT is just that.
Old Mar 23, 2006 | 07:33 AM
I am with you 100-percent on a 1-step cleaner wax. But as soon as you mention anything that is not Zaino, be prepared to be harassed and ridiculed.
Old Mar 23, 2006 | 08:39 AM
DavesZ#3's Avatar
DavesZ#3
This has got to be the most common misconception on this and any other board when the subject of Zaino is mentioned. I wash my car and dry it. I put on a layer of Zaino, usually Z-2. I wait 30 minutes and wipe it off. If I want it extra shiny, I'll follow up with a spray of Z-6 or Z-8.
How is that any more complex or different than any other product out there?
Old Mar 23, 2006 | 08:41 AM
DavesZ#3's Avatar
DavesZ#3
The Terms of Use of this site don't allow for harassment or ridicule, see rule #10. If you are being harassed, please feel free to report the post.
Old Mar 23, 2006 | 09:10 AM
joentown's Avatar
joentown
DavesZ#3:
Will Zaino remove existing swirls? I ask because I too have a Daytona Blue Z and have used NXT but I still have the swirl marks.
Old Mar 23, 2006 | 09:20 AM
DavesZ#3's Avatar
DavesZ#3
The regular Zaino wax Z-2 will do nothing to swirl marks. Zaino Z-5 will help hide the finer ones. The only way to totally remove them is to use a polish like the Z-PC or 3M SMR (Swirl Mark Remover). Those polishes have a fine abrasive in them that physically remove the swirls.
Old Mar 23, 2006 | 12:40 PM
JamRWS6's Avatar
JamRWS6
Why would you change pads. One pad can be used to apply the wax. I can put the wax on the entire car in about 5 minutes with the orbital.
Old Mar 23, 2006 | 01:29 PM
Nexx's Avatar
Nexx
+1, you use Z1 or ZFX periodically not with every application of Z2 or Z5 to remove fine swirl marks. the rest of the products even enhance the shine but are not required. Z2 alone is better then any other 1 step wax out there.
Old Mar 23, 2006 | 01:46 PM
DavesZ#3's Avatar
DavesZ#3
Sorry I didn't specify - I always use ZFX with either the Z-2 or Z-5. Summers are too hot and humid here, I prefer the quick dry of ZFX.
Old Mar 24, 2006 | 05:32 PM
BlueBoxer's Avatar
BlueBoxer
Try 3M products such as Imperial Machine Glaze and Swirl Mark Remover for lighter swirls. They have more aggressive compounds such as SMR for dark cars or I think it was Perfect-It for serious issues. However, be prepared to do several stages i.e. the more severe polish followed by IMG and then your wax of choice. 3M is cheap and readily available.
Jambo016
Sep 16, 2016 01:08 PM
kyin
Oct 15, 2015 05:54 AM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
dcains
Sep 21, 2015 09:28 AM
