Zaino ZFX Flash cure thingy = faster dry time?
Old Jan 29, 2003 | 12:43 PM
grayfox's Avatar
grayfox
Default Zaino ZFX Flash cure thingy = faster dry time?
I've read and reread the info on the Zaino site about their new ZXF "Flash cure" Accelerator Additive and I'm still confused.
Basically, you use/add this stuff to make the wait time between polishes shorter? As in, then you could do more polishes in a day because the dry/cure time is shorter?
Hep!
*edit*
I get it now. NM. =)
Old Jan 29, 2003 | 02:40 PM
stenoslave's Avatar
stenoslave
Yep. Up to three coats per day with ZFX.
Old Jan 29, 2003 | 03:23 PM
grayfox's Avatar
grayfox
Ordered a bunch of supplies today; boyfriend and I are gonna tackle the Eclipse and the Z this weekend. I will try to remember before and after pictures!
Old Jan 29, 2003 | 03:33 PM
Kevin V's Avatar
Kevin V
Here is the short version of the benefits.
(originally from Sal Zaino)
The new Zaino product will be an accelerative additive that can be
mixed with Z-2, Z-3 or Z-5....
Below are just a few of the improvements....
1. When mixed as per directions, you will not need to apply Z-1...
2. It will reduce the drying time, thus making the polish more user
friendly in damp environments...
3. It will increase the gloss factor and extend the durability level..
4. It will have an instant cure time, so you can immediately apply
multiple coats.. No more waiting between coats...
5. And more........
Old Jan 30, 2003 | 06:46 AM
afr0puff's Avatar
afr0puff
Don't 2 and 4 contradict each other? It might cure instantly, but thats only in 80+ degree temps. Isn't it still going to take a couple of hours in 40 degree weather before you can buff and apply the next coat?
Old Jan 30, 2003 | 08:12 AM
grayfox's Avatar
grayfox
Robin from LA Zaino said you can reapply within 20 minutes...I live in CA, so I know it'll be dry by that time...Imma goin' with that.
Old Jan 30, 2003 | 08:26 AM
stenoslave's Avatar
stenoslave
By the time you work your way around the car, it's already been 15-20 minutes and you're ready to wipe off where you started. I've had to wait no more than 35-40 minutes in 50 degree weather (temp inside the garage) when using ZFX.
Old Jan 30, 2003 | 08:45 AM
grayfox's Avatar
grayfox
I'm excited. =)
Doing a full on Zaino action Saturday - wooo!
Old Jan 31, 2003 | 04:22 AM
Kevin V's Avatar
Kevin V
No, the drying is done after applying it. When dry you buff it off.
The curing starts AFTER you buff it off. That is why you have to wait between applications when NOT using the ZFX.
Zaino is completely different from any other product. I was lucky enough to test out the ZFX for a couple of years before its release. I now use it with every coat, even though it isn't necessary.
Old Feb 3, 2003 | 03:40 PM
MastaKillaZ's Avatar
MastaKillaZ
grayfox, how'd it go? I put on my first zaino coat this past weekend too... woohoo... love this stuff.
Old Feb 3, 2003 | 04:13 PM
grayfox's Avatar
grayfox
Hey Masta,
My boyfriend and I flipped a coin and did his car (Eclipse) first and the mine on Sunday. We fought the Santa Ana's all day - made fighting water spotting and wind-blown debris a pain.
Seven hours later and 2 coats of Zaino per car, we were done!
I have to say that I felt I needed to use more Zaino per application than what was recommended on Ira's sheet because it was hard to see how much we were applying. Because of the wind, we had to do the polishing in the garage and a single over head light - so that made it even harder to see.
We both felt that the base paint/clear coat on the Z was shinier than the Eclipse - but then the Eclipse's paint (silver) has a much larger metallica chip, which may have effected the shiny look. I can say that the Eclipse paint hid orange peel much better than the Z paint.
All and all, I'm glad the first Zaino treatment is done of both cars. In retrospect, DON'T DO TWO CARS FROM SCRATCH on the same day. You'll totally exhaust yourself.
Obadabot
Jun 18, 2023 11:31 PM
