Zaino question..
Old May 1, 2007 | 11:15 AM
MemphisZ07's Avatar
MemphisZ07
Default Zaino question..
I did the ZFX with Z5 for two coats, then a layer of z2 by itself. It's been a month now and was going to put on another coat of z2 by itself.. how long do I need to wait to take it off? Also, how long till' I need to use the ZFX again? Thanks for the help guys
Old May 1, 2007 | 01:27 PM
noodleman's Avatar
noodleman
the wait time doesn't matter how many coats you have on. If you didn't use ZFX with the current coat, you'd have to wait an hour or so (on the safe side). After the base coat, I generally don't use ZFX anymore, as I just clean up and take a small break while I wait for the Zanio to dry.
you can use ZFX with the Z2/Z5 as often as you'd like, all it does is that it makes the coats cure faster.
The only exception is when you're doing your first base coat, where the ZFX is required for the Zaino to bond with the paint.
Old May 1, 2007 | 01:32 PM
ldawg32's Avatar
ldawg32
it doesnt matter as long as its dry. if you have the accelerator it dries in 1/2 hr
Mattg350z
Oct 2, 2015 06:51 AM
mcduck
Cleaning & Detailing
Nov 9, 2002 11:30 PM
Dr Bonz
Oct 11, 2002 01:32 PM
z461
Oct 6, 2002 07:33 PM
