Cleaning adhesive off Track Rims
Old Jul 23, 2007 | 09:40 AM
twinship's Avatar
twinship
Default Cleaning adhesive off Track Rims
Don't know where I picked this up, but I have some adhesive junk (like what's left after you peel off a sticker?) on one of my Rays Track Rims.
Soap and water doesn't make a dent.
Any suggestions?
Believe the rims have a clearcoat finish, so I'm kinda scared to use anything that would eat through that or leave a permanent blemish.
TIA!
Old Jul 23, 2007 | 09:51 AM
VO...'s Avatar
VO...
Administrator
Regular Wax or Goo-Gone...
Old Jul 23, 2007 | 01:37 PM
DavesZ#3's Avatar
DavesZ#3
Definitely the Goo-Gone will do the trick.
Old Jul 23, 2007 | 06:58 PM
dkmura's Avatar
dkmura
General & DIY Moderator
3M Adhesive Remover is strong enough to do the job, but easy enough not to remove any type of finish.
Old Jul 24, 2007 | 05:32 AM
JokerDev's Avatar
JokerDev
+1 on 3M adhesive and wax remover or Goo gone
Old Jul 24, 2007 | 08:03 AM
twinship's Avatar
twinship
Thx guys, I'll stop by the local auto supply store and see if they've got any Goo Gone.
Appreciate the advice!
Old Jul 24, 2007 | 08:22 AM
DavesZ#3's Avatar
DavesZ#3
You can get Goo Gone at any grocery store, Wal-mart, hardware, etc. It's not an auto-specific product.
Old Jul 24, 2007 | 08:47 AM
twinship's Avatar
twinship
Even better.
Funny, I never noticed the product before you guys mentioned it. Now I'll probably see it everywhere.
Old Jul 24, 2007 | 02:58 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
More than likely that will be advesive left over from a wheel weight, or maybe a weight fell off. Are you wheels in balance or have just had a balance done??
Old Jul 24, 2007 | 03:01 PM
twinship's Avatar
twinship
The rims were indeed just balanced and mounted.
But the adhesive is on the outer face of 1 of the spokes -- not where a wheel weight would have been. So I'm still not sure where it came from.
Old Jul 25, 2007 | 08:13 AM
VO...'s Avatar
VO...
Administrator
That chit is tough to remove. I had to remove it from all 4 wheels when I purchased new tires and they moved the weights..
Old Jul 25, 2007 | 10:38 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
When I had my last lot of 4 replaced, had balanced, and ended up with some of the weights being moved slightly.
I used a moist, soft towel and gently agitating to removed some of the gunk and the remainder with cleaner wax and then recoated with wax when completed. Don't have goo-gone in NZ . But sounds like that would do the trick.
Can be, but easy does it.
Old Jul 30, 2007 | 10:16 AM
Zazoozle's Avatar
Zazoozle
+1 on Goo Gone. I heart Goo Gone. If you don't have any, you should just buy some to have around when u need it.
Old Jul 31, 2007 | 05:35 PM
twinship's Avatar
twinship
OK, got the Goo Gone, applied per the directions, and it worked as advertised.
Many thx for the heads up... great product!
ablaine
Nov 29, 2016 10:13 AM
_bit
Oct 2, 2015 07:49 AM
